      04-13-2016, 05:34 AM   #1
kokkopa1
Finland
Drives: X1 xDrive25d M-Sport 2012
Park Distance Control unit location in trunk, where?
Where is located 2012 Park Distance Control unit? I canīt find it...
      04-13-2016, 09:07 AM   #2
improvius
Drives: 2015 X1 X28i
What's it supposed to look like? I dug around in the back of mine pretty extensively when I was hunting for my TPMS controller, so I might have stumbled across this one at some point.
EDIT: I went back through the pics on my phone, and I think it's under the cubby in the back of the hatch on the passenger side. If you pull out the hard plastic cubby liner, there should be a slotted foam mold that houses a few different modules. PDC should be one of them.
In the pic below, it is one the right side where the small net is. Pull out the plastic piece behind the net and you should find the module.
      04-15-2016, 12:54 AM   #3
kokkopa1
Finland
Thank you "improvius" very much! Found it, unplugged it (to reset the PDC system) but it didnīt work, so I guess one or more PDC sensor is broken :-(. Have to take it to the dealer to read fault codes.
