      01-03-2017, 02:44 PM   #1
kiloTHREE
Drives: '13 xDrive28i
Converting Wheel Bolts to Studs
Anyone know the length of the stock wheel bolts off the top off their head or what size stud they went with when they converted?
      01-03-2017, 03:07 PM   #2
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
Our stock lug bolts are 12 x 1.5 mm (designated as M12 by some vendors). You should be fine with the 75 mm studs unless you plan on running crazy low offsets
Just FYI, F-series cars and E70 X5's are 14 x 1.25 mm lug bolts (designated as M14)
      01-04-2017, 07:14 AM   #3
PrematureApex
To answer your question, stock bolts are generally described as being 25mm in length, whether or not they're M12/M14 in diameter or 1.25/1.5 in pitch.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      01-04-2017, 07:51 AM   #4
kiloTHREE
Originally Posted by PrematureApex View Post
To answer your question, stock bolts are generally described as being 25mm in length.
Perfect, do you know if that's total length or just the threads?
I have the choice between 45mm and 60mm for studs, 20mm of which is the thread for the hub/rotor clearance.
      01-04-2017, 09:08 AM   #5
PrematureApex
Thread length.
Unless you're dead set on closed ended lugnuts, I'd run the 60s. Although, I think people can still get some closed ended nuts on 60s. 45 seems a bit short. 60 is common, as are longer lengths.
http://www.m3forum.net/m3forum/showthread.php?t=332304
      01-04-2017, 09:34 AM   #6
kiloTHREE
Na running regular open end lug nuts.
I think I'll go with the 60's, may stick out a bit but I'm ok with that.
      01-10-2017, 08:57 AM   #7
kiloTHREE
This is what I ended up with if anyone is curious:
Stock:
      01-10-2017, 09:59 AM   #8
vstolpner
Drives: 2019 F39 X2 m35i
How much did that run you?
And any concerns with the bolts coming loose when taking the wheels on and off?
      01-10-2017, 10:18 AM   #9
kiloTHREE
120 USD
Nope, use red locktite. I ran studs on tracked vw and daily driver for over 8 years, never had one back out.
      01-10-2017, 01:19 PM   #10
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
I would like to see them installed, Im wanting the same thing.
      01-10-2017, 01:23 PM   #11
kiloTHREE
We'll see, it's cold and slushy on my garage floor currently.
Keeps flipping snowing, fun for snow drifto's, bad for cold wet pants.
      01-10-2017, 06:47 PM   #12
D Unit
Drives: 2013 x1 s28i
FYI - ApexRacePartsdotcom makes some nice ones too. They have the nice bullet style ones too.
      01-10-2017, 08:29 PM   #13
kiloTHREE
Here I did one, not seated fully, probably another 5-8mm left to screw into the hub.
50mm (total length) studs with regular open lug nuts would be about flush with the nut when seated.
