12-28-2016, 10:24 PM | #1 |
Rep 1,343
E90 compatible parts?
Hi all, just wondering what other bmw e-series parts are compatible with the E84 X1?
Especially the e9x models as that's what it is based off on right? Wheels Brakes Steering wheel (but LCI e84 is much nicer) Suspension (springs and shocks?) How about the sway bars? Any M components? |
12-28-2016, 10:54 PM | #2 |
Rep 435
It's really hit and miss all over the place.
An example would be the front suspension, we have the same control arms and sways as e9x but different spindle/wheel bearing/strut. Same transfer case and transmission but different axles.... Then we have interior parts like the gas pedal used in f2x, f3x..but share an instrument cluster with e9x. Fog lights from e83 and e70... You get the idea. I guess you could compare it to the z3 in terms of parts bin car status. |
12-29-2016, 08:08 AM | #4 | |
Rep 2,402
The front swaybar is only compatible with E90 xdrives (assuming your X1 is awd), if it's RWD, any e90 front bar will work. Any front bushing/arm for an E90 xdrive works on the xdrive E84. The rear suspension (sans spring/shock length) is all E90. Arms/bushings, etc. Technically, you can bolt on E90 shocks and springs. M3 rear swaybars, subframe bushings, etc. all bolt right on out back (but Ms have different arms and spring shapes vs. standard E90s). Wheels work, brakes work. Sans the wider knuckle, you can think of an xdrve E84 as an E90 xdrive, with a taller ride height. As mentioned above, interior is another story.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
12-29-2016, 08:36 AM | #5 |
Rep 435
12-29-2016, 10:32 AM | #7 |
Rep 2,402
They have a range of wheel diameters, just like the X1 does.
http://www.e90post.com/forums/showthread.php?t=464 Maybe you meant tire diameters? The tires are generally a size-down, yes. But you can certainly still run the slightly shorter (or taller) tire on the X1.
12-29-2016, 11:48 AM | #9 |
Rep 1,343
Thanks for the responses. I'm going to be very selective considering e90 is older than e84 Therefore their parts would be older.
Is the front sways direct bolt on? What would I gain performance wider? I can attest that e60 wheels and tires fit nicely as I am running a winter set from a 535xi. ET20 @19lbs. I like the they are more flushed too. Last edited by Gamb1t; 12-29-2016 at 01:15 PM.. |
12-29-2016, 12:32 PM | #10 | |
Rep 2,402
The M wheels are going to be even lower. Probably like 30 front, mid 20s rear or there abouts.
12-29-2016, 12:34 PM | #11 | |
Rep 2,402
Things like swaybars, etc. don't exactly age...so not much worry there. More importantly, you can used new/aftermarket E90 parts.
12-29-2016, 12:51 PM | #12 |
Rep 296
I can confirm e90 adjustable camber and toe arms fit. I'm currently sitting at the shop while they installed them and are doing the alignment now.
12-29-2016, 01:58 PM | #14 |
Rep 296
My car is lowered aggressively so I needed a way to dial out some of the negative camber. Originally, I was at -3.5 and -3.8 rear camber. Now I'm at -2.25 rear camber and .22 toe out. I requested for zero toe, but the tech said he was highly against it and wouldn't be worth saving the minimal tire tread wear.
12-29-2016, 02:10 PM | #15 | |
Rep 2,402
If not, never go back to that shop again. While I'm OK with 0 toe on this car, factory spec is more negative, with .22 out being way out of spec). Even zero toe on a RWD E90 makes for a rear-end that's arguably too jumpy for the street. .22 toe out would be boarderline undriveable.
12-29-2016, 02:35 PM | #16 | |
Rep 296
01-07-2017, 05:59 PM | #17 | |
Joint Chiefs of Staff
24199
Rep 190,807
