      02-09-2018, 10:05 PM   #1
johninjax
Drives: 2014 X128i LeMans Blue M Sport
Adios
After 134,000 miles my turbo was toast. With that many miles I wasn't going to put too much money into the car waiting for the other shoe to drop. However got a great deal on a 2017 330i. Thanks for all your help.
      02-10-2018, 07:39 AM   #2
Kevman
Kevman's Avatar
45
Drives: 2019 BMW X3 x30i
What were your symptoms that the turbo was shot?
      02-12-2018, 04:01 PM   #3
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
Mine was burning coolant and a little bit of white smoke was coming from the exhaust.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      02-12-2018, 04:03 PM   #4
interceptor428
Drives: 2013 x1 28i/2015 428 m sport
was it leaking coolant...is that what you mean by burning? or was there some type of internal leak?
      02-12-2018, 05:07 PM   #5
Turbod
Turbod's Avatar
It was a seal for the coolant passage through the turbo. I kept getting low coolant warnings. White smoke is due to burning coolant. When I put Pure's stage 2 turbo on, it stopped consuming coolant and the smoke in the exhaust went away.
2023 G80 M3 xDrive
      02-12-2018, 05:18 PM   #6
interceptor428
coolant doesn't mix with oil in the Mitsubishi CHRA (TDO4LR)...I have a backup turbo housing in my hands right now..I literally just pulled it apart and the channel for coolant is separate from oil (and internal components). the white smoke you got was oil leaking past turbo seal (which I have happening on my X1 with no coolant loss). The updated oil cooler line fixes that (temporarily maybe but it there's a TSB on it). You got me scared there for a second. Anyways...good luck with the new car I'm sure it will be fine and you will enjoy it!
      02-13-2018, 12:45 PM   #7
Turbod
Turbod's Avatar
Coolant will never be designed to mix with your engine oil. I have two N55's which the turbo is made by Borg Warner. Engine oil burns blue, coolant burns white, and unbrunt fuel is black. OP is N20 but he hasn't comments since the original post.
2023 G80 M3 xDrive
      02-13-2018, 01:34 PM   #8
interceptor428
Yep good points, but something to keep in mind: when oil leaks out of the turbo (past the seals) and is burned by exhaust gas (not spark plug ignition) it will be white also...which makes people think they are burning coolant
