09-12-2017, 09:09 AM | #1 |
Rep 10,509
Anyone towed with their US spec e84
Hey all,
I looked through our forums and it seems everyone is adding hitches just for bike racks. Has anyone actually towed in the US? I'm trying to figure out if there is a way to code the car to have stuff like different brake bias and stability control while towing and to have the trailer braking controlled without having to add an after market part. Is this possible or is the US X1 really just able to support the trailer lights and needs an after market brake controller? I want to tow a spec Miata on a light open trailer. Should be about a 3500lb load |
09-12-2017, 01:10 PM | #2 |
Rep 105
I have with a rental car trailer for my Z3 BMW. I did install a tow hitch and brake/signal wire kit, nothing else. The thing is to install a tow hitch for your X1 sDrive the car has to have a sunroof, I suppose for more body strength all others can mount hitches for bicycles and those utilities rear racks.
I did tow the trailer only for 230 fwy flat miles , the trailer felt well balance without no problems, next time I'm going to tow something up/down some hills to test the brakes. |
09-12-2017, 03:45 PM | #3 | |
Rep 1,210
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD 2019 Audi TT RS | 10.5@130 SOLD 2020 F97 X3M | 11.0@123 2023 G80 M3 xDrive |
09-12-2017, 04:36 PM | #4 |
Rep 424
Per Invisihitch, the E series X1 can tow 4400 lbs and IIRC the tongue weight is 400 or 440 lbs. You have to have a harness to handle braking on a trailer, the unbraked trailer weight is 2000lbs from what I recall reading. I'd be more comfortable towing with the 35i xDrive model (which I have :-D) or diesel.
http://www.bimmerfest.com/forums/sho...90&postcount=9 |
09-14-2017, 10:25 AM | #5 |
Rep 334
I have an Invisihitch on my Xdrive 2.8 and it tows flawlessly
I have a utility trailer and have loaded it up to about 1500 lbs and towed it with ease. The X1 handles it great and the pulls strong up to highway speed. Mileage easily takes a 5mpg hit. With the Invisihitch, it will pull your Miata no problem.
09-14-2017, 09:23 PM | #6 |
Rep 148
I have pulled a lot of loads with my X1 and Curt hitch. I have a 4x8 trailer and have towed 3300 lbs of modular retaining wall block three times without a problem, as long as they were centered on the axle. One time they were a little behind the axle and I had some sway, but that was not related to the car. I have pulled loads of stone and dirt also, each weighing 2000-3000 lbs. Easy.
I have pulled my dad's car trailer with a heavy load on it, but not a car. The trailer plus load probably weighed as much or more than a Miata and I was comfortable doing it. If I was going to pull a car or other load that would block the X1's tail lights, I would want proper trailer lights, which I do not have. |
09-15-2017, 02:14 AM | #7 |
Rep 132
I just towed a ditch witch (mini skid-steer) with my x1 35i. I have the invisihitch set-up. Towed it no problem. The guys at the rental place thought I was crazy, HaHa. They said it weighs about 3,300 lbs and that the trailer is about 500lbs. No trailer brakes. I just took it easy and the X1 handled it no problem. Highly recommend Invisihitch by the way. Great customer service. I lost my key to the hitch and they sent me a new kit and instructions on how to swap out the locking mechanism for free.
09-15-2017, 02:17 PM | #8 | |
Rep 1,210
09-16-2017, 11:14 AM | #9 |
Rep 424
No worries, I spent a long time looking it up myself before because I wanted to a vehicle with decent towing capacity. I'd have to look up the tongue weight again but the figures seem to be 10-15% of the tow weight is the tongue weight (the 2000lb rated hitches I recall having a 250 lb tongue weight, again calling from memory).
10-11-2017, 04:51 PM | #10 |
Rep 5
Drives: 2015 xDrive28i
I've been towing a 16' Airstream with my 2015 X1 28i since October 2016. Trailer is 3600 pounds empty, approximately 4200 the way I travel. I've done approximately 6,000 miles so far, including some steep grades in Quebec and Newfoundland. Have a Class III receiver, a Tekonsha Prodigy P2 brake controller, an Eaz-Lift Elite weight-distribution hitch with 600-pound bars, and an Eaz-Lift friction sway control. It's an excellent combination. BTW, the E84 is rated to tow 2000 kg. (4400 pounds) in Europe.
hardparker300.00 chance9123.00 |
10-11-2017, 06:34 PM | #11 |
Rep 424
You sir are my hero! I've been thinking about doing this exactly (towing an airstream)! One of these days, I'll get my setup complete to do so.
10-15-2017, 09:05 AM | #13 |
Rep 5
A weight-distributing hitch makes a big difference. Anything more than 250 pounds of tongue weight will have an adverse effect on handling by reducing the load on the steering axle. I have towed Airstreams with 3, 5 and 7 series and X1, X3 and X5 models. 335d in photo pulling a 25.
10-22-2017, 07:42 PM | #15 |
Rep 5
In most states and provinces, brakes are required on trailers with a gross weight over 3000 pounds. In some states the limit is as low as 1500 pounds.
08-07-2020, 06:35 PM | #16 | |
PB Girl
Rep 1
08-29-2020, 10:56 PM | #17 |
Rep 83
This is an old post, and also a forum for the first gen X1 (2013-2015 US) and is a different car than your X1, which is 2016-current. Check out the F48 X1 forum to find the accurate specs for your car. Unfortunately it is a very different car than the first gen, and will have a lower towing capacity.
2013 MG X1 x35i M Sport
09-19-2020, 02:44 AM | #18 |
Rep 246
I know this is an old post, but I wanted to share my experience.
Towed a 5x10 trailer loaded to about 800lbs. I had no issues at all even with hills in CA. I did however upgrade the small 28i brakes with 35i brakes afterwards.. I would consider upgrading the brakes if towing anything heavier that is unbraked. btw I'm lowered on Coilovers with Koni yellows on 350/650 in/lbs |
09-19-2020, 03:13 PM | #19 | |
Rep 952
13 X1 35iX, 98 Z3 2.8, 01 M Coupe, 96 Z3 1.9 DASC, 95 318ti, 13 smart fortwo
09-19-2020, 08:14 PM | #20 |
The Lazy one...
54
Rep 344
To add to this thread as well... I towed this trailer from Nashville to Orlando (took me about 12 hours) and I'm I problems at all!
09-23-2020, 01:05 PM | #21 | |
Rep 1,343
