      02-10-2014, 10:41 PM   #1
dmark1021
Drives: X1
Can trunk pop up by itself if press the trunk button on the key?
Have been driving my x1 for 7000 miles. Suddenly realize this problem. I have keyless entry and ultimate package.
If I press and hold the trunk button on my key, I will trigger the alarm.
But how can I let the trunk open and pop up by itself, instead of push the button on the trunk? Or it does not have this feature? But what is the trunk button used for?
      02-10-2014, 11:05 PM   #2
bosstones
Drives: o_0
I don't have keyless or ultimate, but the trunk button on my key fob is two fold: 1) hold for ~ 1s and release to unlock the trunk, 2) hold for several seconds to set off the alarm.
      02-10-2014, 11:12 PM   #3
dmark1021
Drives: X1
thanks!
my x1 does nothing if hold the button for ~ 1s...
Does your trunk pop up by itself, or you need to push the button on the trunk and lift it?
      02-11-2014, 12:10 AM   #4
Eric5273
Drives: 2014 BMW X1
I have to play with it a bit more to be sure, but I'm pretty sure the trunk button on the remote will only pop the trunk if the doors are first unlocked, so I think you first have to press the unlock button once, and then press the trunk button for about a second, and let go. It will then pop open a tiny bit, but you still have to lift it up manually.
      02-11-2014, 05:54 AM   #5
spydrz
spydrz's Avatar
Drives: '15 M4, '15 i3
06 330i  [7.00]
2002 X5 3.0i  [0.00]
2001 525i  [0.00]
You should not need to unlock the doors to pop open the tailgate.
2002 X5 3.0i/man.*
2006 330i/man./Arktis/Grau*
2001 525i/step./Schiefergrün/Sandbeige*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Dinan Stage 2
*retired
      02-11-2014, 08:36 AM   #6
danielj
Drives: 2018 x2
I don't think you can get the hatch to "pop up by itself". It just has a latch/lock - unlatch/unlock feature. I know on some models modifications can be made so the struts lift the lid once it's unlocked but not seen that done with the x1.
      02-11-2014, 08:42 AM   #7
spydrz
spydrz's Avatar
06 330i  [7.00]
2002 X5 3.0i  [0.00]
2001 525i  [0.00]
Exactly. It pops open, but like on most cars, you have to raise it yourself. No electric trunk struts.
2002 X5 3.0i/man.*
*retired
      02-11-2014, 08:43 AM   #8
Gort
Klaatu Barada Nikto
Gort's Avatar
Drives: 2017 X3-35i
You may already know that you can also release the trunk by pushing up on the little pad above the rear license plate?
      02-11-2014, 08:45 AM   #9
bosstones
Drives: o_0
Originally Posted by dmark1021 View Post
thanks!
Ah, that's what you meant. Like danielj posted, it will only unlatch the boot lid. You still have to manually raise it (i.e. no auto-open/close).
Correct. You can have the doors all locked but still unlatch the hatch and open it.
      02-11-2014, 08:57 AM   #10
Red Bread
Drives: Smog machines
Yeah, it rarely works on ours, plus it's easier to just grab the latch instead of pulling the key out of my pocket.
      02-11-2014, 10:27 AM   #11
mullini
Mullini
mullini's Avatar
Drives: 2017 i3 BEV
I'm another X1 owner who has given up on the trunk release button on the remote. It seldom works, and only if I am so close to the trunk at that point I might as well just unlatch it manually anyway. One of my minor complaints about the X1.
      02-11-2014, 03:21 PM   #12
Royleblue
England
9
Drives: BMW X1 18d Sport
Useful feature if you just want to put something in the boot - sorry, trunk!- without unlocking the car. Just make sure you have the key before you close the tailgate again.......
      02-12-2014, 11:01 AM   #13
kvanoman
Drives: BMW X1 xDrive 28i M
Press the button for approx 2 seconds, when you hold it down longer it will set off the alarm. It's just a learning curve. I'm not a fan of how the button works, nor how the tailgate is so slow to respond when you go straight to the button on the vehicle. My wives CRV works much better. Other than the lack of better thought out storage, I love the X1!
      02-12-2014, 04:08 PM   #14
d1saster
Bulgaria
59
Drives: F15 N55 & E93 N51
This can be coded, but there are complications if you have alarm and comfort access.
      02-13-2014, 06:27 AM   #15
donsbabybeamer
Drives: 2014 x1
There is definitely a learning curve. after 9 months I am bale to hold the button just long enough to pop the lock without setting off the alarm. I fond that if you hold the button for about 1 second release and then hold the button again it always unlocks. The most important factor is to listen for the lock click when it unlocks and them immediately release the button on the key fob.
Hope it helps.
      06-22-2014, 08:28 PM   #16
dmark1021
Drives: X1
Thanks everyone!
      06-22-2014, 10:39 PM   #17
Grovsnus
Flight Lieutenant ≛
Drives: Le Mans blue X1 35i
That's not useful, because you have to lift the trunk anyhow. You might as well just touch the opener on the trunk with the same hand you are to lift it with.
Given that it's one more way a hacker might possibly gain access to the interior of the car without physically breaking in, I'd say it's worse than nothing.
If it had longer range, so you could pop open the trunk from the doorway so someone else could get something in or out of it, it would have been useful. But the range is so short that you might as well use the button on the car and save yourself from digging for the key.
      06-25-2014, 05:30 PM   #18
Royleblue
England
9
My original post was before I picked up the car, and I expected it to be the same as the VW where you can open the boot from the key fob without unlocking the whole car. I think the arrangement on the BMW is so that you cannot lock your keys in, like I nearly did once. I unlocked the boot, put the keys in my coat pocket and then put my coat in the car. Just realised in time before I closed the tailgate.
      08-28-2014, 03:37 PM   #19
BMWBig6
BMWBig6's Avatar
28
Drives: BMW X1 sDrive28i M Sport
Has anybody tried to replace the struts/dampers on the rear liftgate with higher rated units so that it does raise automatically as soon as it's unlocked ("popped" open)? Or would that risk banging at the top of the liftgate's travel? I know, sounds crazy, but I just wonder if a $20-$40 part substitution would achieve a similar result.
2015 BMW X1 sDrive28i M Sport / 2019 Mercedes E450 Wagon / 2015 Porsche Boxster GTS
Favorite Former Rides: 11 Ford F-150 Limited | 09 A4 S-Line Avant / 08 Audi TT S-Line / 03 Ford SVT Lightning / 01 Ford SVT Lightning / 93 BMW 740iL / 90 BMW 535iM / 86 Porsche 944 Turbo / 83 Porsche 944
      08-29-2014, 10:13 AM   #20
Carlin/14/E84
Drives: 2014 x1 bmw
[QUOTE=Grovsnus;16171239]That's not useful, because you have to lift the trunk anyhow. You might as well just touch the opener on the trunk with the same hand you are to lift it with.
From inside the vehicle, usually I open the tailgate by using the button by the driver's footwell. I seems the tailgate on the initial unlock lifts a bit higher than using the key-fob.
      08-29-2014, 01:50 PM   #21
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
I was wondering when someone would mention the inside front release button. I make deliveries in mine, and have lots of loading/unloading, and "comfort access", so I've gotten used to the various quirks. I sure wish you could option a power liftgate, though.
