      01-02-2014, 02:48 PM   #1
Nealcp
Drives: 2013 BMW X1
Talking Spacers for my X1?
Hi all...fairly new to this community and to my X1...I'm thinking of having wheel spacers installed on my X1. I have 18" wheels. Has anyone else done this? Thoughts? Also, what dimension spacers? Thinking 12mm front, maybe 15mm rear? TIA!
      01-02-2014, 04:14 PM   #2
squishy
Zimbabwe
153
Drives: 2014 Ford Mustang GT
I know a few people have installed wheel spacers, and I haven't read about any problems with them, outside of whatever is common with wheel spacers (vibrations, etc.).
Wish I could be of more help than that, I'm sure someone will chime in.
      01-02-2014, 05:09 PM   #3
AFDnic
Space grey X1
AFDnic's Avatar
Drives: BMW X1 2012
I have H&R 15mm front and 20mm in the back for about 1year and no issue works perfectly
Thanks God for German Engineering
      01-02-2014, 05:57 PM   #4
Nealcp
Drives: 2013 BMW X1
Do you have 18" wheels? 4WD or 2WD?
Thank you! Like how they look? Handle?
      01-03-2014, 12:02 AM   #5
Sennasixty8
Drives: 2014 X1 35i ///M Sport
Just put 12mms on the rear of my xdrive 18" m sport non staggered.
No problems, no vibes, fills the rear out better than stock.
      01-03-2014, 10:34 AM   #6
AFDnic
Space grey X1
AFDnic's Avatar
Drives: BMW X1 2012
I have 19 for summer and 17 for winter... I really like the look its more agressive and it handle perfectly... I don't have any Cons
My X1 is a Xdrive 28i
Hope this help you
      01-09-2014, 12:01 PM   #7
Booster
Pave The Rainforest
269
Drives: Wagon
2007 335i Coupe  [0.00]
Where are you guys getting your spacers from?
Sold: 2015 Pyrite Brown M3
Sold: 2020 Sunset Orange M340i Xdrive
Sold: 2021 Bluestone 540i Xdrive Msport
      01-09-2014, 01:28 PM   #8
Nealcp
Drives: 2013 BMW X1
I ordered mine from Berger Motorsports...Have them on already...they look great; can definitely tell the difference, visually...haven't really pushed them so I can't speak to performance. I did run my right front into the curb already though so have a nice curb rash I need to get fixed...they stick out more...
      03-10-2014, 08:18 AM   #9
annoyingmouse
Drives: bmw x1 xdrive28i
What kind of jack did you guys use, and what jack points?
      03-10-2014, 08:54 AM   #10
Black Flagged
Black Flagged's Avatar
Drives: M2C
use a standard floor jack, there are four pads that are mounted under the car. the points are behind the front tires and the rear are just in front of the rear tires. if you have a hocky puck put that on top of the jack before you lift up the car to make good fit between the jack and car. good luck...
      03-10-2014, 10:06 AM   #11
Black Flagged
Drives: M2C
Here's the mount
      03-10-2014, 12:05 PM   #12
annoyingmouse
Thanks, I saw those and thought surely they were too flimsy and had to be for something else. Yes, jack pad is a must from the looks of it.
I'll be going 15mm all around.
      03-10-2014, 12:25 PM   #13
Black Flagged
Drives: M2C
Will look really nice..
      11-30-2014, 07:10 PM   #14
MMacx1
MMacx1's Avatar
Drives: 2016 BMW 340i M
Spacers
On my factory 19"
Front 15mm Rear 18mm from Burger Tuning No rubbing
      12-01-2014, 04:05 PM   #15
BeemerX1
Belgium
14
I have H&R 20mm at the rear.
I have chosen not to do in the front as it looks good like this.
Also de spacer is bolted on the car and then the rim bolted on the spacer.
No vibrations, handling is still the same, xdrive model.
