      10-20-2015, 04:08 AM   #1
PeterDS
Drives: X1 2013
auto-leveling Xenon headlights
hi,
My xenon auto-level doesn't work. doing some research on the net brings up multiple causes such as:
- vertical aim sensors (front and back)
- head light vertical aim control
both of these look allright, nothing broken or extreme rusted.
when a vertical aim sensor is broken or not working it seems that the headlight is dropping down and not going upwards, nothing happens in my case! I don't hear any noise (motor) when lights are turned on.
I suppose that there is an electronic part involved somewhere which might be the cause of this? Does someone has an idea which part it is and were it is located?
thanks,
Peter
      10-20-2015, 01:06 PM   #2
vstolpner
Drives: 2019 F39 X2 m35i
Only thing I can suggest is look at a BMW OEM parts supplier (realoem.com if I'm not mistaken), they would have parts diagrams that would help you locate what you're looking for.
Is the engine light coming on our are you getting any errors? Maybe try an OBD scanner to read any faults?
Alternatively call the dealer and ask them to give you a suggestion.
