      10-18-2019, 08:25 PM   #1
danfratamico
danfratamico's Avatar
Drives: 2007 BMW 335xi
2007 BMW 335xi  [0.00]
E84 Hard Brake Pedal After Valve Cover Replacement
My valve cover was cracked, so it was replaced with genuine parts. The vacuum pump needed to be removed in order to take the cover off. After the parts were replaced, I no longer have the ability to brake easily. The brake remain hard both during start up and while engine is running for minutes. The vacuum pump was correctly installed and based out against the engine block. All brake vacuum hoses are intact. Is it possible my vacuum pump has failed? If so, what could have been the cause? Any help is much appreciated!
      10-19-2019, 12:46 AM   #2
0w40X1
Drives: 2014 BMW X1 s28i M Sport
Obviously they didn't complete the fix.
Tell em to find it on their dime.
Pump didn't just fail right when they worked on it.
It's some wrong reinstall.
      10-27-2019, 10:22 AM   #3
5mall5nail5
Not stock
5mall5nail5's Avatar
Drives: E34 525i Turbo
Sounds very much like they split, cracked, broke, didn't install a vacuum line.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM
1992 525i
1987 325e
