      04-09-2018, 06:29 AM   #1
2quik
Drives: 2015 X1 Xdrive 28i
Center Console Arm Rest Wobble/Play
On my 2015 X1 28, I am experiencing alot of movement in the arm rest.
It moves alot from side to side. Is anyone else experiencing the same?
Thanks
      04-09-2018, 07:19 AM   #2
SpeedPunk
Drives: 14 X1 35i M Sport
Yes, there are two plastic trim panels on the inside of the armrest that cover maybe six small bolts that secure it to the hinge. Take two minutes, and mine had just backed out over time. Threw a bit of threadlocker on it and it’s been fine ever since!
      01-30-2019, 08:00 AM   #3
tnmurphy
Drives: X1 2013 XDrive35
My center armrest is wobbling too. A small spring came out. The spring is the size a retractable pen spring. Is there a sticky on removing the center arm rest to repair it. I think maybe a plastic tab broke on the underside of the lid but it could be a screw too. I can't see it well enough to figure out what it needs. The arm rest still moves backward and forward, bearings are are still working but with the wobble it won't last long. I think maybe the bearing track has lost one connection point.
      01-31-2019, 10:21 PM   #4
nillan
Drives: 2015 X1 x28i
i had the sliding console cover in my 2015 x1 replaced twice under warranty.
