      01-28-2016, 11:38 AM   #1
gordon_23
Drives: G31 520xD
X1 E84 nav 609 FSC generate.
Hello,
I wait for my BMW X1 E84 with pro-nav (609) to be delivered. I was previously extracting DE file from my F31 with ENET cable and E-Sys to generate FSC code for NBT nav update. I was wondering if it is also possible to extract 1B (? or is it still DE?) file with ENET cable and E-sys in X1 E84 and using generator to generate FSC for sat-nav update?
If so is there any difference in E-Sys parameters?
If not what kind of tool (cable, soft) do I need to accomplish it?
Thanks in advance!
      02-06-2016, 09:12 AM   #2
Djorre
Drives: BMW 520 Touring and BMW X1
You cannot use your Enet cable, you need the expensive ICOM cable to do that
      02-26-2016, 02:14 PM   #3
gordon_23
Drives: G31 520xD
Hi Djorre,
Just for your (and anyone else interested) I was able using ENET cable extract 1B file using method explained here: http://www.e90post.com/forums/showthread.php?t=1154524
Used Total Commander for FTP connection and then HEX edit to perform necessary edits. After that FSC generator worked perfectly on 1B. So it can be considered as alternative just for FSC generator (not for coding of course).
Take care and thanks for answer.
Tags
e84, fsc
