      04-02-2016, 11:27 AM   #1
BeEmVe
Drives: '14 X1 x28i M-Sport
Dashboard Trim Removal
I recently received a retro fit heads up screen for our buggy and was looking to install it.
http://f30.bimmerpost.com/forums/sho....php?t=1063158
The following need to be removed:
Left dashboard cover 51 45 ...
Bottom left and right dashboard trim 51 43 195
I found the left dashboard cover labeled as 10 in this diagram:
https://www.partsbase.org/bmw/x1-e84...ent-panel-top/
At this point I am assuming that the bottom left and right dashboard trim are parts labeled as 1 and 3 in this diagram:
https://www.partsbase.org/bmw/x1-e84...-panel-bottom/
What bugs me is that the numbers from install instructions do not match the part numbers in the diagram. Any thoughts?
At the same time any else take their dash a part?? Any tips or tricks?
      04-05-2016, 01:10 AM   #2
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
To me it looks like the whole dashboard needs to be removed to accommodate the necessary connections. As a start I am attaching some of the instructions. Let me know if you need others.
Seagull288.50
      04-05-2016, 07:09 PM   #3
BeEmVe
THANKS for all of those. Is there one for:
Removing and installing/replacing instrument panel trim, bottom right.
That would be trim "around" the glove box.
I do not think I need to take the whole dash apart as with the trim removed I should be able to route the cable.
      04-06-2016, 12:36 AM   #4
d1saster
Bulgaria
60
This should be it
      04-06-2016, 09:08 AM   #5
BeEmVe
That was it THANKS again.
      04-07-2016, 08:33 AM   #6
IslandTimes
Drives: 2013 X1 sDrive28i
Didn't even know there was a HUD available for the X1. Where did you buy it from? Let us know how the installation goes and your impressions!
