      12-31-2014, 08:20 AM   #1
PrematureApex
Clunk When Reversing and Applying Brakes?
'14 N55 X1.
I get a significant bang or clunk out of the rear of the car sometimes when reversing and I begin to apply the brakes.
Appears some 335 guys get the same thing...brake pads shifting in the carrier apparently.
Anyone else experience this?
      01-19-2015, 03:25 PM   #2
X135iM
X135iM's Avatar
Drives: 2015 X1 35i Msport
I have the same issue. And my x3, and 335 sometimes did the same thing. Other cars have heard same thing even. I BELIEVE I only hear it AFTER PARKING w/ emergency brake use. Try without it .. just my $.02
      01-21-2015, 10:34 AM   #3
flguy400
Drives: X1
I hear the same thing when I have had the car sitting with the emergency brake on.
I start the car, lower the emergency brake, put the car in reverse and then start backing up. I hear the clunk right after I start moving.
Not sure what it is, but I don't like the sound. Could it be something like the hill brake that is applied when you are stopped at a light when uphill?
You know how if you come to a red light and your going uphill, once you stop you can take your foot off the brake completely and the car will stay there. I forget what its called, but I believe its a brake assist thing to help keep the car in place until you hit the gas.
      01-21-2015, 01:47 PM   #4
X135iM
X135iM's Avatar
So just to confirm, I drove a Honda and a Toyota today that did this exact thing ... EVERY time reversing after moving forward. I'm assuming pads moving a few MMs in their holder.
15 X1 35i Msport LeMans Blau/Schwarz |Ultimativepaket|JB4
07 X3 Monacoblau/Grau Prämie|KaltemWetter|Komfort|Navigation
tschüss : ( 11 335d JBD Tiefseeblau/Oysterschwarz |Prämie|Navigation|KaltemWetter|Sportpaket
      01-21-2015, 08:34 PM   #5
Teutonic
Teutonic's Avatar
The brake pads are "glued" to the discs due to the heat after parking if you use the hand-brake. If is cold outside is more obvious.
Do not use the hand brake if not necessary.
Anyway, nothing to worry about.
      01-22-2015, 06:57 AM   #6
PrematureApex
Pads? Don't you mean shoes? I assume the X1 used shoes for its parking brake...
