      10-11-2014, 02:12 PM   #1
zero-2-sixty
Drives: X1 xDrive35i
Question LED reverse, turn signal and brake lights
As you all know, our 2013+ X1 does not have LED turn signal (corner of headlight cluster), brake lights and reverse bulbs. Look close at stock bulbs and you will see that they are incandescent. Why we don't at least get LED brake lights is a mystery. We do have LED tail lights and turn signal in the side view mirror.
I brought LED aftermarket bulbs from Weisslicht and installed (sorry no pics). Now I have flickering or what some would say is periodic strobing of the new bulbs. All bulbs were canbus and NO signal problems requiring any resistors. I think the computer is reading the lower voltage and the intermittent strobing is a test of some sort checking for bulb failure. Is there a way to code this out? Anyone had an issue like this. BTW, they were easy to replace, even the brake lights in the tailgate. Help...
      10-15-2014, 02:30 PM   #2
BMWBig6
BMWBig6's Avatar
28
Drives: BMW X1 sDrive28i M Sport
Sorry I can't help you, but I've subscribed in case a solution is posted, and I'd love to see some pictures of the final result.
2015 BMW X1 sDrive28i M Sport / 2019 Mercedes E450 Wagon / 2015 Porsche Boxster GTS
Favorite Former Rides: 11 Ford F-150 Limited | 09 A4 S-Line Avant / 08 Audi TT S-Line / 03 Ford SVT Lightning / 01 Ford SVT Lightning / 93 BMW 740iL / 90 BMW 535iM / 86 Porsche 944 Turbo / 83 Porsche 944
      10-16-2014, 10:10 AM   #3
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
Even they advertise canbus error free (whatever that means) i don't believe they can put 20 wat resistors in the bulb housing. Even if there's resistor integrated it would create heat that can damage the housing. I put led reverse light and disabled the bulb check via coding.
      10-16-2014, 05:18 PM   #4
zero-2-sixty
What code sequence do I need to use? Can dealer do it?
      10-16-2014, 06:30 PM   #5
d1saster
Bulgaria
60
The best way for me is a OBD2 cable with the software as described in the E90 coding forum. Next alternative is BMWhat app + Bluetooth or wifi obd2 adapter.
Yes the dealer CAN do it but idk if they are willing to do it.
