      01-18-2014, 08:58 PM   #1
MarioTunes
Drives: BMW X1 2012
ECU, footwell module 3 partnumber problem
Hello
I have problem with my "ECU, footwell module 3", when I start the car, I got the message that the back stop and day light light are not working, but they are working good.
I was told that I should replace "ECU, footwell module 3". The current part number is "6135 9249082-01" (please see picture attached), I can't find this part number in the catalog.
Question, is it possible to replace it by another one?
Car: BMW X1 xDrive 28i Canada (based on vin made March 2011), I can provide VIN number if needed.
Thank you
      01-19-2014, 10:28 AM   #2
NormB
Drives: 2014 X1 xDrive 28i
Covered by warranty?
Wouldn't this be covered by the warranty on your 2011 X1?
      01-19-2014, 03:09 PM   #3
MarioTunes
Drives: BMW X1 2012
No warranty
No warranty for this car.
Thank you
      03-13-2014, 11:24 AM   #4
Thgblt
Brazil
Drives: x1 3.0 28i e84 2011
Did you know if this module must to be Codified?
      03-13-2014, 06:01 PM   #5
MarioTunes
Drives: BMW X1 2012
Yes, it should. Your local dealer can do this or local mechanic if he has right equipment.
      03-14-2014, 08:19 AM   #6
Booster
Pave The Rainforest
269
Drives: Wagon
2007 335i Coupe  [0.00]
Most current part number is:
61-35-9-308-371
But, if you PM me the last 7 of your VIN, I can double check...
Sold: 2015 Pyrite Brown M3
Sold: 2020 Sunset Orange M340i Xdrive
Sold: 2021 Bluestone 540i Xdrive Msport
      03-14-2014, 09:05 AM   #7
MarioTunes
Drives: BMW X1 2012
61-35-9-308-371
Hello,
Thank you for reply. VIN number is VM57049.
I have found OEM# 61359263805 on ebay will it work with my car?
Thank you
      03-14-2014, 10:09 AM   #8
Booster
Pave The Rainforest
269
Drives: Wagon
The number I provided for you was the correct number for the latest version...
The 61-35-9-263-805 did not show in my database... But also, the number on your part in the picture you provided didn't either...
In all honesty, I bet the ebay one would work after programming...
