      03-18-2011, 08:46 AM   #1
IanSmart
Scotland
Drives: 320i X Drive M Sport
Fuel cap flap
Anyone having trouble with theirs? Mine often refuses to open and I have to use the manual release inside the boot. Been in to dealer once already but want to see if anyone else has experienced this before going back again.
      03-18-2011, 10:57 AM   #2
mario486
Mario
mario486's Avatar
Scotland
26
Drives: X1 XDrive 2.0d, Mini Cooper
No, mine has been fine. It's not that you have not unlocked all of the doors? Sorry dumb question but I do it from time to time.
"Do or do not, there is no try!" - Master Yoda
"Always in motion is the future" - Master Yoda
"Truly wonderful, the mind of a child is" - Master Yoda
"There is no passion to be found playing small - in settling for a life that is less than the one you are capable of living" - Nelson Mandela
      03-18-2011, 11:29 AM   #3
Gatekeeper
Gatekeeper's Avatar
France
11
Drives: BMW 320d Security
Fine here, as long as the car is indeed unlocked.
"Let our manners distinguish us from our enemies, as much as the cause we are engaged in"
      03-19-2011, 01:28 AM   #4
melts
Singapore
9
Drives: X1 sDrive18i
Yup. I do sometimes forget to close it after fueling (as the attendant does it for me) resulting in me having a minor panic the next day realizing the flap was not closed. To my delight, I realized it's not possible to close (or open) when your doors are locked.
There's a possibility to change the option on your on-board computer allowing you to select if you'd like the driver's door and fuel flap to be opened when you press once on your remote control or to have all doors (including the boot) to be opened once you press the remote.
I find having only the driver's door and fuel flap safer.
      03-19-2011, 03:10 AM   #5
Gatekeeper
Gatekeeper's Avatar
France
11
So problem solved ?
      03-19-2011, 04:03 AM   #6
mario486
Mario
mario486's Avatar
Scotland
26
Good point, forgot about that.
Here's another scenario that can happen:
When you pull away the car locks itself. Stop at the filling station, take the key out of the ignition and open the drivers door. At that point only the drivers door unlocks. Walk to the filler cap and its still locked! I have done this many times. I now make a habit of pressing the unlock button on the dash when I fill up.
      03-19-2011, 04:05 AM   #7
LRS
Dead Head
LRS's Avatar
Drives: E92 335d Coupe
Location: (Then > Bay Area, Calif) (Now > Southeast, UK)
Hey Ian
Had exactly the same problem on ours.
I solved it by spraying a little silicon spray lubricant on the locking pin and the slot which it goes into when locked.
Problem solved!
E92 335d SE Auto | Space Grey | Black Leather | 19” 230 Star Spoke | Comfort Access | Lumbar | Heated Seats | Black High Gloss Trim | Pro Nav | Assist | Bluetooth Telematics | Voice Control | High Gloss Shadow Line
      03-19-2011, 04:10 AM   #8
terryd
Drives: Honda S2000
Hi Ian,
I had the same problem with the filler cap which surfaced after using the first ever tank of fuel! The dealer does seem to have resolved it on the first attempt though (which was back in November).
Cheers
Terry
      03-19-2011, 10:44 AM   #9
ocosta
Drives: Buying a X1
I had the same problem.
Since day 1 i noticed some noise from the fuel flap cap when i lock or unlock the x1. After a few fuelings it didn't open at all.
I took it to the dealer and until now the problem is solved.
      04-03-2011, 12:30 PM   #10
IanSmart
Scotland
Got mine set not to autolock and only open the drivers door and fuel flap. The locking pins just doesn't withdraw far enough some times. Will keep it well lubricated to see if it makes any difference.
      10-15-2011, 02:15 PM   #11
dafblue
Drives: 2010 x1 20sdrive
Hi Ian! Wondering if you got fuel flap proplem resolved?
I have had same problem with mine since new, not just year old as yet and going in to dealer for 5th time next saturday!! They have replaced the actuater on 2 occassions which sorted the fault for a couple of months and then back to square one again!
      01-04-2012, 06:32 AM   #12
IanSmart
Scotland
Sorry not been around for a while. Not had any problems recently.
