      08-25-2020, 11:00 AM   #1
bassrebel
The Lazy one...
Drives: 16 C300 4Matic
Cooling fan trouble shoot?
Hey Guys!
I recently had an engine hot warning message while idling waiting for takeout food. After I started driving it back home the message went away, which lead me to suspect that the water pump and thermostat were not the culprits.
I installed Bimmerlink on my phone and ran the error messages and there were no error messages about water pump, so I was relieved. I also put the water pump in the Bimmerlink dashboard and I can see it running, which is good!
Now, I have seen that the cooling fan is not activating... not when the car was warm, not when I turned AC on, or even the heater.
Is there a way of troubleshooting the cooling fan to see if I can make it work again before buying a new one?
Thanks!
Follow me on Instragram @bassrebel
2014 BMW x1 x3.5i 2016 Benz C300 4Matic
      08-26-2020, 06:47 AM   #2
bassrebel
The Lazy one...
So I went ahead and purchased a new fan/shroud combo... I’ll report back if that ends up working =]
      08-31-2020, 11:59 AM   #3
cwickberg
Drives: X1 35i MSport Ultimate,
check the thermostatic switch and relay first... Apply 12 volts to the fan to see if it runs...THen you can eliminate the fan
      08-31-2020, 01:03 PM   #4
bassrebel
The Lazy one...
Thanks! Where do I find the switch?
Thanks!
      09-02-2020, 06:00 PM   #5
bassrebel
The Lazy one...
Soooo I got my fan today and as I’m detaching it I realized it wasn’t working because it was impacted by a piece of trim... took the trim out, put everything back together and tested the car and it’s working perfect, no overheating issues, temps are fine, water pump not overworked
      09-07-2020, 07:34 AM   #6
cwickberg
simple fix! Good Job
