      10-19-2021, 09:15 AM   #1
hbadotti
Drives: X1 E84 2015
Question Garage Opener (433 MHz) + High Beam (Bi-Xenon)
Good morning, I've a TX Car, it's a remote control (433 MHz) which you use it in car... You can install it in any fuse, like high beam, horn, etc.... It's your choice.
I always used it in my high beam, so you don't have to horn at 3 a.m. You've a "+" cable which you can connect to a fuse and a "-" cabble direcly to battery or anyother ground spot.
The problem is, my headlight is Adaptative Bi-Xenon, then I don't have an exclusive wire for high beam, I got only signal wire (which I don't know if it's 5v or 12v) which sends only a small pulse to the headlight module.
Anyone have ever installed a TX Car (garage opener) in a adaptive headlight? I googled for this, but didn't find anything!
      10-19-2021, 06:10 PM   #2
jaykaybimmerguy
Drives: BMW X1 - E84
My question is why?
      10-20-2021, 12:58 PM   #3
hbadotti
Drives: X1 E84 2015
Originally Posted by jaykaybimmerguy View Post
My question is why?
If you try to think for a minute,
- Your car controller will never run out of battery
- You won't loose signal range because of battery
- You'll have a stronger signal because car works with 13-14v
- You'll never forget your controller in home, because it'll be always inside your car
- You can open your garage door with 2 hands on steering wheel
- I want it
That's enough?
