      08-11-2022, 01:56 AM   #1
GuamX1
GuamX1's Avatar
Guam
28
Drives: 08 BMW 135i, 08 128 Cab
Headlamp Switch
How do you remove the headlamp switch it is not as easy as the other BMW's are. You cannot just pop the panels around it. Can someone help me I need to remove the switch and replace the knob. I already broke the vent..... Need help please
2013 BMW X1 * 1973 Clubman GT * 2016 Mazda MX5 * 2000 Honda S2000
2004 BMW 325i Touring * 2009 BMW X5 3.0xdrive
      08-11-2022, 06:52 PM   #2
orca4wd
Drives: X1, Z3M
Take a look at below link on pictures to show side panel removal to access headlamp switch. This is straight-forward process but need to care not to break the clips holding the panel. Good luck!
https://e84.xbimmers.com/forums/showthread.php?t=933675
      08-11-2022, 07:33 PM   #3
GuamX1
GuamX1's Avatar
Guam
28
Hmmm I should do that mod too while I am in there, so it is the side panel that is taken out. Does it have a screw?
      08-11-2022, 08:20 PM   #4
orca4wd
Drives: X1, Z3M
The mod to activate the rear fog lights is easy and requires taking apart the switch. I have done this a long time ago so can't remember all the steps. If I recall, no screw on removing side panel and switch. But taking apart the switch to cut the dummy fog button does have screws.
      08-14-2022, 07:19 PM   #5
GuamX1
GuamX1's Avatar
Guam
28
Finally replaced my switch knob and did the tab delete and now have my rear fog light working. I had to also remove the bottom tray under the steering wheel
