04-04-2017, 05:41 AM | #1 |
Rep 12
X1 PDC / DSC Buttons
Morning all, a new X1 owner here,
I have a strange situation whereby the buttons on the dash for the parking sensors, traction control and hill descent don't appear to do anything (no lights etc when pressed) yet the systems attached to them still work just fine. Any thoughts? |
04-04-2017, 09:33 AM | #2 |
Rep 673
Likely a connection issue. If you're under warranty still have your dealer look at it.
If not under warranty then first thing to try would be to disconnect the battery and give it a few minutes for the computers to fully reset. If that doesn't help then take apart the dash to get to the connector for those buttons - disconnect, inspect connection, and if all seems good then reconnect and see if that helped. (Make sure to disconnect the battery when working on the dash in case you short something by accident) |
04-05-2017, 07:33 AM | #3 |
Rep 12
Cheers, will give that a try, no warranty to worry about but I'm sure that panel worked when I bought the car last year so a connection issue may well be a good shout.
