      10-25-2015, 07:50 PM   #1
b00gers
Drives: bmw x1
My car was hit while parked - transmission question.
Hi everyone.
My X1 got hit today while it was parked. I did not engage the parking brakes.
I came back to my car and saw it on the sidewalk - roughly 20 feet from where it was parked. My rear end damaged and my passenger wheels are messed up from hopping the curb. One wheel also looks like it has a few degrees of negative camber.
Luckily the other party was still there and very cooperative when I arrived.
I had to start the car and drive it back onto the street. There were no problems. So I decided to drive it home instead of waiting for a tow truck. As I was driving, I was thinking how far my car moved while it was parked. I am not sure what I should do. Driving home, there were no problems. It felt very normal. But I am afraid there are things I can not see or will not surface till later on.
Any idea on what I should do? I am taking it to a body shop in a couple days but I am not sure if they would look for hidden issues, like in the transmission or suspension.
I thought getting my first door dent will put me past the baby stage. This is quite the jump!
Thanks in advance.
      10-25-2015, 08:47 PM   #2
leatherpants
Hide Encased Member
leatherpants's Avatar
Drives: 2013 X1 xDrive28i
If it's an insurance issue (the guilty party's insurance, presumably) then by all means have everything checked out - especially alignment, etc..
      10-25-2015, 08:49 PM   #3
vstolpner
Drives: 2019 F39 X2 m35i
Can up your dealership and ask if they do this sort of work or if they have a list of approved body shops. If you end up going with a different shop that BMW doesn't approve then they might blame you next time you get warranty work done.
      10-25-2015, 10:50 PM   #4
BeEmVe
Drives: '14 X1 x28i M-Sport
Given the damage you have described I would not have driven the car and waited for the tow truck. At this point if there is damage you could get into a pissing match about whether it was from the hit or from you driving it.
At this point, I would suggest that you do not drive it anywhere but to the dealer for an inspection.
      10-26-2015, 10:36 AM   #5
b00gers
Drives: bmw x1
Thanks everyone. I will be calling the dealership in a moment.
It is odd because it seems like the car was actually rolling. There are no flat spots on the tires or marks on the ground. Is that to be expected?
      10-26-2015, 10:47 AM   #6
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
why didnt you get it towed?
hopefully its just cosmetic repair.
