      06-22-2018, 11:39 AM   #1
sudermatt
Drives: 2015 X1 35M
Is the sport package different than the M sport package?
I'm looking at a couple of used X1s that are model year 2015. I've seen the M model, but I'm also looking at one that has the sports seats and the M Wheels but on the door sill it says BMW sport not M sport. Has anybody seen this? Is this a special model?
      06-22-2018, 12:48 PM   #2
kiloTHREE
Drives: '13 xDrive28i
You could spec almost anything on these, the only things you couldn't individually spec is the areo package and the "sports" suspension outside of the M IIRC.
Originally Posted by PrematureApex View Post
What a jackass...
      06-22-2018, 01:34 PM   #3
sudermatt
Drives: 2015 X1 35M
So this car might not have the sport suspension
      06-22-2018, 01:38 PM   #4
kiloTHREE
Just grab the vin and toss it into any of the online decoders:
https://www.bmwvin.com/
What a jackass...
      06-22-2018, 04:06 PM   #5
LevinBR
Drives: 2013 BMW X1 xDrive 35i
M sport has different suspension, sway bars, and torque split (20-80 vs. 40-60 on other models). It also has "performance control" torque vectoring, staggered wheels, and the M-sport steering wheel.
Turbod395.50
      06-22-2018, 08:19 PM   #6
Chicone
Drives: 2015 X1 X35i M-SPORT
So I’m a new 2 week owner of a 2015 X1 X35i M Sport. The tires were replaced before I bought it, but they are all the same size. 225/45/R18. The VIN decoder shows BMW LA wheel, M Double Spoke 355. Can I go back to a staggered setup when these wear out? Looks like I need to figure out what I’m going to do about the spare too, because they are not run flat, they are Kelly Edge A/S, not what I would have bought, would have preferred Michelin Pilot Sport. My first post, glad to find you guys, lots of good information and I’m already a major enthusiast!
      06-26-2018, 09:28 AM   #7
Vidgamer
Vidgamer's Avatar
10
Drives: BMW X1 e84
My Msport does not have the staggered wheel setup. The rims and tires are the same. I have s-drive if that matters.
From what I've read, the only suspension change is that Msport has stiffer springs.
      06-26-2018, 10:10 AM   #8
hooligan_G01
Space Shuttle Door Gunner
hooligan_G01's Avatar
6430
Drives: 2022 X3 M40i BG/Taco Red
I think the torque split is a myth and not all M Sports came with staggered wheels (mine has the 18" square setup, for example), I believe all the 19" OEM wheel setups are staggered on the X1, though.
      06-26-2018, 12:33 PM   #9
PrematureApex
And not to knit-pick, but the car has open diffs front and rear iirc, so it physically can't "torque vector" as that term is typically intended to mean. 50/50 split to each side of the diff at all times.
It will grab an inside wheel brake, etc. to induce yaw/fight understeer though.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
Turbod395.50
LevinBR39.50
      06-27-2018, 12:09 PM   #10
LevinBR
I didn't know that some M Sports came with a square setup. Cool.
I have a feeling that the front/rear torque split change for the M sport is a myth too... anyone have any hard evidence on this?
I don't see any mechanical differences in the drive line.Torque distribution between front and rear is variable and controlled by an electronic actuator in the transfer case, so technically a different default front/rear split could be programmed into M sport cars (software).
      06-27-2018, 12:12 PM   #11
hooligan_G01
6430
I have been able to find no BMW literature, or even reputable aftermarket tuner, that supports the claim of a different F/R torque split. The only thing I found that referenced it was a Cars.com(?) article or something.
I agree it is possible, but if it was true, I'd expect to be able to find something from BMW regarding it.
      06-28-2018, 01:25 AM   #12
BeEmVe
Drives: '14 X1 x28i M-Sport
Yes, M-Sport wheels can be staggered or square. Ours is square which is great cause with two sets (winter summer) we have a spare.
      07-02-2018, 03:50 AM   #13
TitanSilverE46
Australia
Drives: 2014 X1 E84 , 2017 2201 AT F45
Mine is a 2014 sDrive20 MSport It has the 19" staggered wheels:
Style 225 8J x 19 with 225x40 Front
Style 225 9J x 19 with 255x35 Rear
I don't think the sDrive20 was available in USA but is here in Australia.
      07-02-2018, 01:39 PM   #14
LevinBR
same here. I do worry about tread depth differences messing with the drive train, though (in the case of using a spare)
      07-18-2018, 12:38 PM   #15
Chicone
From the sales brochure it looks like they upped the speed limiter if you opted for the staggered wheels. I'm considering swapping my back two wheels for the 18 inch staggered version or maybe going to 19's.
-Steve
      07-18-2018, 07:28 PM   #16
Lucky13
Lucky13
My 2013 MSport sdrive 28 (enough fricken letters and numbers) came with staggered wheels and I know the brakes are not standard as well as body and suspension.
Were still on the original pads at 47,000 miles with pads to spare.
      07-18-2018, 10:15 PM   #17
mcdanielvzw
mcdanielvzw's Avatar
144
Staggered F's with the driveability and ruins the experience. MY personal opinion.
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights
Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH
About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake
Sold - 2009 328i - Stock, 195,000 running strong.
      07-20-2018, 05:30 PM   #18
FunkyTang
Drives: 85325e 98540i 08335i 14X1-35i
My online sticker shows two M sport configs
Pic at
View post on imgur.com
      07-20-2018, 09:33 PM   #19
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
The performance option is for xdrive to apply brake at individual wheel to correct vehicle traction
      07-26-2018, 08:02 PM   #20
sudermatt
Drives: 2015 X1 35M
so my next question is....
does the sport line have anything other than better seats and trim chnages?
any suspension or machanical upgrades?
      07-27-2018, 06:38 AM   #21
mcdanielvzw
144
(My) Sportline 35i has better seats and different exterior trim. No suspension or mechanical upgrades.
      08-23-2018, 12:57 AM   #22
Gamb1t
Gamb1t's Avatar
Referencing the various years' sales brochures on the E84 X1, there are 0 mentions of torque distribution being different. The M Sport package is mostly aesthetics. Beefier suspension is a 35i configuration not MSport. I assume many MSports are 35i therefore one can easily associate this package with beefier suspension.
Referencing the BMW Complete Vehicle document (google for it), the X1 shares the exact same transfer case for the same years. There are variant changes which is supported by realoem.com. The document describes in some technical form on the handling dynamics of X1s. No mention of 20/80 power split. Default is 40/60. Varies according to conditions. Jump on the gas hard and it's 0/100.
The torque vectoring mentioned about is the Performance Control feature SA 2VG. Check VIN decoder to determine if your car has it. It's an option code available to any X1. The feature basically utilizes braking to counter under/over steer conditions.
HTH.
