      05-30-2018, 01:23 PM   #1
BeingWithBimmer
Drives: 2015 X1 2.8i sDrive
New X1 Owner - Wheel Fitment Question
Hey Guys,
Just bought a 2015 X1 base model by retiring my 2007 X3. I am loving the X1 ride so far and its amazing in spite of being smaller than my previous X3 this car does drive and feel really great. However, since I got a base model (at a hard to say no price) the 17" factory wheels are not something I am jazzed about and would like to upgrade to either 18s or 19s. I have been reading around on this forum on last few days and have shortlisted some used set of wheel/tire combo that I would like to buy but I want to make sure they fit. I am sure I have ready a post about these exact set-up a few days back but for some reason can't seem to find it. It would be great if anyone of you who has used this staggered combination can throw some light on the question below.
Front: 8.5 Width with 35mm offset
Rear: 9.5 Width with 37mm offset
Not sure they tires that are mounted on these but I believe they must be 225 40 R19 front and 255 35 R19 rear. Please advice if this can fit X1 and if any spacers would be needed or they just mounted straight in. Thanks for your help.
      05-30-2018, 01:52 PM   #2
KWX1
KWX1's Avatar
25
Drives: X1 Xdrive35i
They will fit. No spacers needed.
2014 X1 Xdrive35i /BMS intake/JB4/ GFB DV/CPE charge pipe/ VRSF downpipe/ Alpina TCU flash
      05-30-2018, 02:34 PM   #3
BeingWithBimmer
Thanks! Appreciate your response. Will post the pictures once I have them on.
      05-30-2018, 03:56 PM   #4
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
There are a couple of good offset calculators out there.
Using the one on tiresize.com it looks like fronts would be fine (only 0.04" closer - way less than I went with my 245 40 R17s on a 30mm offset). The rears may need spacers as they would be 0.67" closer, as the wheel offset at 37mm is taking you the wrong way for a wider tire.
Measure how much clearance you currently have and see if you have at least 0.7" (preferably a little more).
      05-30-2018, 06:12 PM   #5
Dalco450
Dalco450's Avatar
Drives: X1 M-Sport
No spacers needed in rear.
19’’ x 9’’ ET41 OEM
So 19’’ x 9,5’’ ET37 is only 2,35mm closer from the suspension.
So, my MPS A/S 3+ are 5mm larger of the border of the wheel. No rubbing at all.
Sorry for my english.
