      02-20-2023, 09:06 PM   #1
Mikethepatsfan
Drives: bmw x1
bmw x1 2013 engine malfunction reduced power
I just had a valve cover gasket replaced and everything was running perfect before that now I get engine light on and power reduced on the screen, has anyone else ever experienced this issue and had it fixed? Could it be my DME software? Been reading into a lot of different things I don’t know what to do…
      02-21-2023, 01:15 PM   #2
maxwmiller
Drives: 2013 X1 xDrive2.8i
Hey Mike, a few questions:
1) Did it run normally after the valve cover gasket replacement?
2) Who replaced it? Indy? Yourself? Dealer?
3) Do you have a code reader and if so, what code is it displaying? This is your best bet of troubleshooting the issue.
      02-21-2023, 01:20 PM   #3
Mikethepatsfan
Drives: bmw x1
It is showing code p052b and it ran perfectly fine before valve cover was done, would you think it’s the vanos?
      02-27-2023, 07:05 PM   #4
huntshaded
Drives: toyota
2) Who replaced it? Indy? Yourself? Dealer? x trench run
Would you suppose it's the vanos if it's showing code p052b and it ran absolutely fine before the valve cover was replaced?
