      07-28-2018, 08:57 PM   #1
55/Rad
Drives: 2014 X1 XDrive 35i
Accessing MAP Sensor on N55 X1
Thinking about doing the Stage One tune and can't seem to find the MAP sensor. BMS instructions aren't clear for this old brain.
It certainly isn't easy to see, so I assume removing the airbox is in order.
Do I remove the entire airbox or just the top? Is there anything else to look for?
Thank you!
55/Rad
      07-28-2018, 10:04 PM   #2
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
Thank you!
55/Rad
You can access it by popping up one of the plastic engine covers. If you mean the TMAP sensor it is located in the chargepipe on the back right before the throttle body.
Location of MAP sensor is below.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      07-29-2018, 01:45 AM   #3
55/Rad
Much better photo - very helpful- thank you! Definitely looking for the MAP. So, better to remove the airbox housing or micro pollen filter box for best access?
55/Rad
      07-29-2018, 09:40 PM   #4
PrematureApex
55/Rad
I just pry the cover up a bit if you only need to plug/unplug. No need to remove anything.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      07-30-2018, 12:09 PM   #5
Turbod
Turbod's Avatar
55/Rad
On the X1 you will need to remove the cabin air filter and cowl. Like PrematureApex said, after that just lift the cover up to access it. You don't need to remove the entire cover.
2023 G80 M3 xDrive
      07-30-2018, 01:59 PM   #6
55/Rad
I removed the airbox and lifted up the cover underneath, which allowed me to get my hands on the sensor. It took a bit to work it - the TMAP was much easier - but it eventually came apart.
BMS Stage One was installed and everything went back together easily.
Like everyone else who has gone this route has said - the performance differences are quite noticeable.
Thanks again for your help.
55/Rad
      07-30-2018, 04:55 PM   #7
Turbod
Turbod's Avatar
I haven't tuned my X1 yet but when I added the JB4 to my 335i I didn't notice any performance gains. I'm glad to hear that you noticed a difference.
2023 G80 M3 xDrive
