      05-29-2013, 04:31 PM   #1
usc335
Drives: '21 M2C, '08 E92 335
X1 x35i DS Shifting Issue?
I just took delivery of a 2014 X1 x35i MSport and may have a shifting problem, but I'm not sure if it's normal. With the transmission in Sport mode, the car refuses to automatically shift into 6th gear even when cruising on the freeway. The only way I can get it to shift into 6th is manually upshifting or putting it into D. Is this normal? Thanks.
      05-29-2013, 04:36 PM   #2
nospam
Drives: 2015 Alpina B6; 430i; X5 40e
Yes, it is normal. DS is a 5sp transmission program.
      05-29-2013, 07:46 PM   #3
danielj
Drives: 2018 x2
Common to lock out the top gear in sport mode so you keep the power closer to the sweet spot for better responsiveness.
