      04-15-2014, 12:18 PM   #1
Udyr
Drives: 2014 X1 x28 xLine
Disable rear PDC via hitch light, where to plug in?
I have an aftermarket hitch and bike rack on my X1, and it makes the rear PDC make a continuous tone everytime that I go into reverse...very annoying.
I've read over on Bimmerfest that several people with X3/X5 have had success with adding a simple $10 tow light and connecting it via a "4-pin to 7-pin" connector, which adds enough resistance/draw to make the ECU think there is a proper trailer turn signal.
Has anyone done this before? Where should I be looking for the connector?
Any help would be much appreciated.
      04-15-2014, 12:27 PM   #2
cwickberg
Drives: X1 35i MSport Ultimate,
Based on my research, the X1 does not have the connector and electrics to make this happen as it is not approved in US for a hitch.
probably can just hit the switch on the console to tunr off the PDC or at least disapble the sound via Idrive
Let us know what you find
      04-15-2014, 12:41 PM   #3
Udyr
You can't turn the sound all the way off via iDrive sadly. Just down
I'm going to give the dealer a call to see if one of their techs would know.
      04-15-2014, 01:47 PM   #4
HBWT
HBWT's Avatar
11
Drives: 2013 X1X 2.8
There is no 4 pin or 7 pin connector. You will have to install it yourself. I've done it and it will take about 1-2 hours depending on your ability. Soldering will be difficult as the space to work in is tight. Solderless connectors are a bit easier but still difficult because of limited room to work. Small hands and good vision(neither of which I have) will make the job much easier. I soldered my connections.
      04-16-2014, 01:39 PM   #5
Udyr
Do you have any info about how to wire this up?
I might have to take the plunge.
