      12-03-2016, 04:26 PM   #1
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
Coilovers owners - how HIGH can you go?
Wondering if theres anyone out there with aftermarket coilovers that did not lower their X1's significantly (15 mm or less) or even possibly raised it.
I am currently eyeballing some KW V1's and was just curious if any brands in particular could achieve this.
| 3-IM | AA Headers | Eurocharged Stage-3 | BMW PI |
      12-03-2016, 06:29 PM   #2
vstolpner
Drives: 2019 F39 X2 m35i
I recall seeing someone who raised their X1 and posted about it here. Not sure what he used but I'm use if you search here or the fest forums you'll find it.
I'm on the phone so can't easily search.
      12-03-2016, 08:59 PM   #3
DUI Elite
///M at Heart
DUI Elite's Avatar
90
I should clarify, I have seen the thread about the Eibach lift springs, but I actually don't want to lift it either.
Wondering if there are any aftermarket coilover setups that can mimic stock height (to essentially take advantage of the better dampening only).
      12-04-2016, 09:06 AM   #4
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
With my KW V3, they are on the highest setting and I am pretty low.
      12-04-2016, 10:11 AM   #5
mwtrogus
Drives: 2014 X1 35i
I have KW V1 kit and have the rear at the absolute max for height for winter and there is about a 1 to 1.5 finger gap. I'll be honest it doesn't ride the best at this height as I think the struts are at top of stroke and it is more or less bouncing on the springs with little dampening. It's fine and still better than stock struts with oem or h&r
      12-04-2016, 05:33 PM   #6
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Interesting. Thanks guys.
Only option might be to just swap to sport package springs and run Bilstein HD shocks/struts.
Does anyone know how much the OEM M sport springs lowers the X1 compared to non-Sport? Looks to typically be 10-15 mm based on what I see from other chassis.
      12-05-2016, 10:47 AM   #7
LevinBR
Drives: 2013 BMW X1 xDrive 35i
Why not keep stock springs and put in Bilstein HD (B6) dampeners? I plan to do that very soon.
      12-05-2016, 02:15 PM   #8
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Thats pretty much the route I'll have to go but I'm not sure if the M Sport springs have a better spring rate too or if they simply lower the cars.
      12-08-2016, 03:52 PM   #9
Redblox
Drives: 2014 x1
OP i have a set of m sport spring and strut if you need.
