View Poll Results: Coolant Top-Off Frequency | |||
~ once per year | 2 | 16.67% | |
more than once per year | 4 | 33.33% | |
less than once per year | 2 | 16.67% | |
never | 4 | 33.33% | |
Voters: 12. You may not vote on this poll |
12-05-2018, 02:45 PM | #1 |
Rep 137
35i Owners; How Often do you Top Off Coolant?
I seem to have to top off my coolant once every 6 months. My local dealer says this is normal, even for new cars. What's your experience?
12-05-2018, 05:18 PM | #2 |
Rep 372
I've topped it off probably 2 times in 3 years. Once every 6 months where it gives you "coolant low" seems a little much.
X1 35i, H&R springs, Bilstein HD shocks, BMS JB4, BMS chargepipe, xHP trans flash
bosl_y0.00 |
12-06-2018, 02:07 PM | #3 |
Rep 438
I did it on 3/8 and 6/20 of this year. I've had the car since 07/17 though.
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake Sold - 2009 328i - Stock, 195,000 running strong. |
12-06-2018, 02:47 PM | #4 |
Rep 12
I just recently had to add about 2 cups. Hadn't checked since back in May when I replaced the exploded coolant tank. I believe that temperature change can have a slight impact on fluid level over time as well. It was in the 70s when I last filled and bleed the system. Now it is in the 30s-40s so I wasn't too concerned about the lower level. Both my ZHP (M54) and X3 (N52) also have to be topped off about twice a year.
Mr.TenEighteen6.00 |
12-07-2018, 02:48 PM | #5 |
Rep 254
never.
Mod List: Twisted Tuning MHD tune, XHP3, ER Charge Pipe, catless DP, ER Competition FMIC, Pure Stage 2 Turbo, PURE High Flow Inlet Pipe, ER Outlet Pipe, GFB DV (Plus), Gruppe M intake, Supersprint full exhaust
12-11-2018, 08:33 AM | #8 |
Rep 268
Not normal. Check expansion tank for evidence of bleed off. Our tank showed dried residue by the cap and eventually the seal in the middle failed and you saw dried trails on all sides of tank.
New tank installed (went after market since quality german part failed in < 50K miles...) - b |
12-19-2018, 01:54 PM | #11 | |
Rep 137
I see no external signs. If the leak is internal, I've learned about the following symptoms, yet I have not observed them: - leaking into heater core: smells like maple syrup in the cabin - leaking into cylinders: white smoke coming from exhaust - leaking into oil: oil looks like chocolate milk |
12-28-2018, 10:08 PM | #12 |
Rep 2,233
They wanted to replace a second coolant expansion tank for me 30k miles after the first replacement. They found the radiator was leaking too after I complained that couldn't be normal. New tank and rad under cpo
03-06-2019, 11:05 AM | #13 | |
Rep 137
The cooling system on these cars is really dumb, in my opinion. The expansion tank is basically a pressure cooker made of plastic. We all know about the pump too, it was also built with weak plastic components and is prone to failure. Last edited by LevinBR; 03-11-2019 at 08:47 AM.. |
03-14-2019, 05:31 PM | #15 |
Rep 2,233
Have them check the radiator too. Mine was leaking and caused 2 expansion tanks to fail somehow. They think the radiator was causing the tank failures. It's been good since never had to top up all winter
