      09-30-2013, 07:15 PM   #1
Mtpisgah
Drives: 2010 WRX & 2013 X1
Rear hatch closing effort adjustment
My wife has problems closing the rear hatch on my X1 because the shocks are too stiff. Is there a way to adjust the pressure on these to make it easier to close?
      09-30-2013, 08:42 PM   #2
EpistemicConfusion
Likes Cars
Drives: X1 xDrive28i
But other than that
      09-30-2013, 08:59 PM   #3
HBWT
HBWT's Avatar
11
Drives: 2013 X1X 2.8
no
      10-01-2013, 09:17 PM   #4
Mtpisgah
I will let you recommend that EC. If i do it, she will hit me with the barbell.
Thanks HBWT, hopefully they will loosen up some with time as has happened on every other wagon/SUV I have owned. A few years from now.
      10-01-2013, 10:25 PM   #5
Grovsnus
Flight Lieutenant ≛
Drives: Le Mans blue X1 35i
Actually, the weight comment might have been unintentionally helpful.
Placing weights inside the rear door might make it easier to close. If there's 5 lb more weight there, that's 5 lb less pull she would have to do.
      10-02-2013, 11:53 AM   #6
0w40X1
Drives: 2014 BMW X1 s28i M Sport
I'm 61 and weak, and yeah, it's firm, but it'll get weaker, and I'll tell you what's a real bitch.
Just think if you are bent over into rear, and weak struts allow the hatch to slam on you.
It's happened to me on camper shell window, and not fun.
      10-02-2013, 01:27 PM   #7
EpistemicConfusion
Likes Cars
Originally Posted by UMBC2015 View Post
She might have it easier, but her X1's struts certainly won't.
Plus, in order to get that full 5 pounds of weight to help her, it would need to be located precisely where she closes the door from. If it is located too high up on/in the door, it won't amount to the full 5 lbs of assistance, so to speak. I know that's too technical, but something to consider.
I definitely do not recommend it.
I was just working on finding a place in my trunk for a traffic triangle which I bought from Bimmerzone in hopes of finding a euro traffic triangle that slots into the provided holder on the hatch lid....haven't found a place yet, but it does tell me something about the hatch struts: They are designed to hold at least 1 more pound (roughly) of weight, placed as far forward as the euro-traffic-triangle-holder.
How much help would a pound be? I don't know, but it couldn't hurt.
      10-02-2013, 07:48 PM   #8
danielj
Drives: 2018 x2
I dislike having to slam it shut. Embarrassing when friends or coworkers are with me.
      10-03-2013, 08:09 AM   #9
briar08
Drives: 2014 BMW X1 28i SDrive
No need to slam, you just need to get past the half way point and let gravity do the rest. The harder you slam, the worse it works.
      10-03-2013, 08:54 AM   #10
Grovsnus
Flight Lieutenant ≛
It may still be easier to replace struts than the wife's shoulder.
Anyhow, the struts shouldn't take damage from just a few pounds. When staying open or being closed, the work is the same: zero. Think about it - the struts holding the car up don't get worn on a car sitting on the showroom floor.
It's movement that wears struts. Kinetic energy. And when actually closing the trunk; whether the force then comes from an arm or a dead weight doesn't matter to the struts. The speed of closing does. I'm pretty sure those things are dimensioned for several times the load, so they won't break just because someone lifted or closed the hatch twice as fast as normal.
      10-03-2013, 08:59 AM   #11
danielj
Drives: 2018 x2
Perhaps they eventually changed something on recent models but I've tried every possible way. You think it's closed then the dreaded "trunk open" light comes on.
      10-03-2013, 09:03 AM   #12
Red Bread
Drives: Smog machines
Yep, slam it every time or the light comes on. I did it for twelve years with my last BMW and the shocks lasted the whole time.
      10-03-2013, 09:42 AM   #13
EpistemicConfusion
Likes Cars
Perhaps the solution might lie in switching your struts to the 2014 struts? I too shut it to slightly more than halfway, and gravity carries it the rest of the way.
      10-03-2013, 09:44 AM   #14
Red Bread
Could be, but I'm not the OP, I don't have any issues closing it. My 5'3" wife has a little trouble with it, but not enough to monkey around with changing the struts for a small difference. Ours is more a latching issue than an effort issue. You're right that once it's partially down, it tends to bring itself down, ours just seldomly latches completely, so once it pivots down, I tend to give the license plate a good shove to ensure it latches. RealOEM also lists one part number for the struts for all E84s, regardless of LCI or not and doesn't list a change for 2014.
      10-03-2013, 01:14 PM   #15
COOLGREANY
Riding BMWs since 1977
COOLGREANY's Avatar
124
Drives: 24 xDrive28i Space Silver
Hmmm, I could swear there was a triangle delivered with mine - maybe because we picked it up in Germany?
      10-03-2013, 05:38 PM   #16
EpistemicConfusion
Likes Cars
My understanding is the one that fits there isn't DOT spec, and thus cannot be sold here. Or some such nonsense.
