      09-26-2010, 03:03 AM   #1
Diesel-King
Spain
Drives: BMW X1 sdrive18d
BMW X1 radio removal?
Hi,
Anyone knows how to remove the radio in a BMW X1?
Should be similar to the 1-series, see post here for this: http://www.fitaudio.com/?View=entry&EntryID=164
But just want to be sure before ripping all off....
      10-06-2010, 05:31 AM   #2
Diesel-King
Spain
Finally, I figured it out myself!!!
BMW X1 Radio and Upper Dash Compartment removal:
- First you have to remove the centre console plastic cover underneath the A/C unit. Put a firm grip on it an just pull it straight backwards.
- Now the A/C unit (and trim) can be removed. Just pull it straight towards you. It's fastened at each end side (no screws).
Unclip the 3 connectors on the back side of the A/C unit and remove the console cover and A/C unit.
- Now you should see the 2 screws holding the radio in its place. Loosen them and lift out the radio. Unclip the antenna connector and the big radio connector.
Now you have it!!!
- If you want to remove the upper dash compartment (with the lid). First remove the complete dash trim (including the two fresh air intakes).
It is a single piece that is attached to the dash with several "male/female" type of clips. Carefully start on the far right side inserting a screw driver underneath…it will pop out gradually…
Be careful not to damage. When removed, loosen the central locking cable.
Now you should see the 3 torx screws holding the dash compartment. Loosen these an then just lift out the compartment.
I used this procedure to integrate my TomTom XL in the dash compartment. 12V I took from the cigarette lighter cables.
I have done a "sliding mechanism" that enables a permanent install of the TomTom not visible from the outside….
      10-07-2010, 08:27 AM   #3
ives1960
Drives: BMW X1
Sorry fot my english
Diesel-King
Hello is it possible to show photos of your artwork, I am interested in your system for tomtom xl, thank you
      10-07-2010, 02:22 PM   #4
silber1
Drives: x1
Have a look to:
http://www.motor-talk.de/forum/anten...-t2920288.html
here I have some pictures how to. The text is in German, but images are in English ;->
      10-08-2010, 03:55 AM   #5
Diesel-King
Spain
Well, the procedure is not exacly the same as in a X1 but similar....
Here is my home-made permanent Tomtom XL install in my BMW X1:
Hope you'll enjoy it!
      10-12-2010, 08:21 AM   #6
ives1960
Drives: BMW X1
tanks for you reply
delivery of my car Friday yes....
