      01-15-2014, 04:26 PM   #1
halfmoonclip
Drives: X1 28i
Toggle to show engine temp?
This appeared in another thread, but the 'how to' remained unanswered, so I thought I'd post it separately.
The other thread referred to some means of adding 'engine temp' or 'coolant temp' to the list of checks that can be accessed from the left stalk toggle; the same one that currently offers to check the oil or recognize the tire pressures.
So the question; can engine/coolant/oil temperature indeed be added, and how is it done?
And a giant Bronx cheer to the damnfool who gave us 'manifold vacuum' but no temp gauge in the 4 cylinder cars. What were they thinking?
Moon
      01-15-2014, 06:43 PM   #2
Twix
Twix's Avatar
Drives: 2011 e91
It can be programmed by your dealer
      01-15-2014, 08:24 PM   #3
halfmoonclip
Drives: X1 28i
And all you need do is ask?
Thnx,
Moon
      01-15-2014, 09:30 PM   #4
Twix
Twix's Avatar
Drives: 2011 e91
The first session should be free, I'd make a list of all the programming you want then get it all done at once. After that I'm sure you're wallet would hate you. That's what my dealer told me anyways. Go in and ask, they should give you one free session though.
      01-15-2014, 11:11 PM   #5
halfmoonclip
Drives: X1 28i
What else is possible? Daily fuel mileage perhaps? Oil and or coolant temp? Anything else you can suggest as useful?
Thanks,
Moon
      01-16-2014, 08:21 AM   #6
Twix
Twix's Avatar
Drives: 2011 e91
There's a post on this forum somewhere that lists everything. Pretty much any engine sensor can be displayed
      01-16-2014, 09:32 AM   #7
halfmoonclip
Drives: X1 28i
Twix, can you give me a little bird dog on where to look? I had a quick look to no good result; hence this post.
Thnx,
Moon
      01-16-2014, 10:44 PM   #8
Twix
Twix's Avatar
Drives: 2011 e91
http://e84.xbimmers.com/forums/showthread.php?t=854900
5 min search. The list shown here is still just a few of the things that can be programmed.
Give a good search in the e90 forums, those guys are more knowledgeable about programming
      01-22-2014, 09:03 PM   #9
halfmoonclip
Drives: X1 28i
Okay, inquired of our salesperson, who then checked with service.
They were unable to do any of these things, according to her.
Any more guidance to offer?
Moon
      01-22-2014, 09:29 PM   #10
Twix
Twix's Avatar
Drives: 2011 e91
They can do it. Clearly your dealer isn't very helpful. There's lot of guys on the E90 forums that program for people for cheap. I don't know any of them because my dealer is super wicked awesome.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      01-22-2014, 09:49 PM   #11
BeEmVe
Drives: '14 X1 x28i M-Sport
Slightly OT any one ever set the fan speed with defog? When I turn on the defog the fan goes full blast which is typically over kill. I'd like to set it to a mid speed.
Here is a list that I have collected from another source (I can not comment on the accuracy):
Convenience & Operational Options
***9744; Close windows/sunroof with key fob
***9744; Fold/unfold mirrors with key fob
# ***9744; Open/Close liftgate with key fob/in-cabin button
***9744; Auto unlock doors when engine is stopped
***9744; Auto eject key fob when engine is stopped
***9744; Set wipers to complete cycle when shutting off the car
***9744; Disable headlight washers
***9744; Enable one-touch window operation with door open
***9744; Disable seatbelt butler for driver
iDrive
***9744; Disable iDrive "Accept" screen
***9744; Disable iDrive camera disclaimers
***9744; Add/Remove weatherband radio
? ***9744; 8 preset buttons instead of 6 (uses Mode and AM/FM buttons for CIC)
Gauge Cluster
***9744; Enable digital speedometer in gauge cluster
***9744; Enable real-time MPG
***9744; Enable shift suggestion in 6MT
***9744; Instrument cluster lighting always on
Alerts
***9744; Disable key in ignition chime
Lighting
***9744; Disable corner ambers
***9744; Enable Euro double blink hazards lights
***9744; Disable auto dimming mirrors
? ***9744; Disable cornering lights (E92 or E70)
? ***9744; Angel eyes as day time running lights (E90 3/2007+ build)
Premium Options
***9744; Enable DVD in Motion (Requires CIC idrive or CCC with DVD Changer)
***9744; One touch Blinker Count Change (2, 4, 5, 6, or 7 blinks)
***9744; Fold in mirrors at any speed while car is in motion
***9744; Fold in mirrors immediately when doors are locked
***9744; Remove lighting errors and warnings for aftermarket lights
***9744; Disable seatbelt chime for driver ***9744; Passenger
Retrofit Options
? ***9744; Bluetooth activation (requires 2MULF, antenna, and mic)
***9744; Disable TPMS
***9744; Other retrofit coding
Navigation Updates
***9744; 2014 BMW On-Board Navigation System Update (CIC idrive)
***9744; 2014 BMW DVD Navigation Maps (CCC idrive)
Software Updates
***9744; Alpina B3 Flash for N54/N55 engines (335i/135i)
? ***9744; E9x M3 DME 240E Flash
? ***9744; E9x M3 Euro DCT Flash
