      06-09-2017, 07:54 PM   #1
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Turning rotors?
Has anyone turned the rotors on their X1?
Just curious as I've been told by both my dealer and a BMW specialty shop that they do not. The dealership says they install pads without turning the rotors if they are in spec and the specialty shop says they replace the rotors every time.
I'm not sure what would be unique about BMW rotors that you couldn't turn them???
      06-09-2017, 11:32 PM   #2
andybmr
Drives: 2015 x1 xdrive 28i
turning rotors
They don't recommend it. Try brake performance good prices on cross drilled rotors. will be tying them out its time to replace mine.
      06-10-2017, 07:05 AM   #3
bucketfoot
bucketfoot's Avatar
I'm leaning towards slotted.
I won't touch a drilled rotor. They are just for looks, do nothing for performance and have to many problems with cracking.
      06-10-2017, 05:06 PM   #4
andybmr
turning rotors
they also have slotted rotors for good price
      06-12-2017, 01:25 PM   #5
kiloTHREE
Drives: '13 xDrive28i
Lower tolerances. I can't give you specifics but I've been told a few times that the amount of usable/sacrificial metal available on the zimmerman/bmw rotors is less than most.
Again, I've never measured new vs lowest rated spec. But that makes sense if true.
I've always been a fan of turning rotors if it can be done within spec.
      06-13-2017, 11:34 AM   #6
fiehlsport
Drives: '13 X1 xDrive35i
I had my factory rotors turned and they still vibrated afterwards. Could've been the shop's fault but hey, maybe there's a reason they don't recommend it.
A pair of Carquest painted rotors from Advance Auto cost me $90 after coupon and look just as good as stock, and perform great even after flogging them on the track.
