      11-05-2019, 02:40 AM   #1
bartekb85
Drives: e84
1.8 d xdrive 2010 143 KM Strange sounds on a hot engine
Hello, I have a problem with the e84 143 hp xdrive year 2010. The problem is squeaking like a multi-V belt. It squeaks only on a hot engine, and only when leaving the revs. Replaced belt for a new Continental, checked rollers, whether there is no slack or no bearing, the crankshaft pulley also looks ok, the alternator without the clutch so I rather exclude it, covers also nothing changes, so I would exclude it. I am attaching a sound file. Best regards and thank you for your help.
      11-16-2019, 01:43 PM   #2
alex1991
Drives: E84 2011
So, the only thing I can tell you is, that when we have sound coming from the belt and sometimes the silicon spays helps a lot.
Give it a try, it is lest then 8$
