      09-24-2017, 04:23 PM   #1
fused7
Drives: X1 2.0 Xdrive
Sat nav reactivation
I purchased my X1 in Costa Rica and back in 2014 they didn't offer sat maps for CR so my car had the sat nave deactivated on delivery. My vehicle however has sat nav. Is there a way to re activate my sat nav. The maps for CR are now available on all new cars here now so the only issue is getting he maps installed.
I haven't asked the dealer yet. Thought I'd put it out here first and see if anyone knows another way that couple save a few bucks.
      09-25-2017, 09:08 PM   #2
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
Do you have coding setup? If yes, you can use vin decoder to see if there’s an option listed that disables navigation. If there’s such option you need to remove it from Vehicle Order and code default CIC. If that works cool, if not you need to purchase FCS code from dealer.
      09-26-2017, 09:18 AM   #3
fused7
Thanks. There is a deletion.
I have S609A Navigation system Professional
Then I have S837A Delete navigation system
I don’t have coding set up. Any quick tips on getting that setup or a good link to run through it? I’ll have a look and see if I can work it out.
      09-26-2017, 02:47 PM   #4
d1saster
Bulgaria
60
Go to the E90 coding subforum. There’s lot of info there.
      09-26-2017, 04:50 PM   #5
fused7
Thanks
