      11-14-2023, 02:43 PM   #1
w.nieciag
Drives: X1 E84
Car audio
Hi, i have a problem.
I cannot play music from my phone by plugging it with USB cable, the car does not even "see it".
Is there something I can do ?
      11-14-2023, 03:18 PM   #2
brumbrum69
Drives: BMW X1
I had the same problem with iPhone but when I tried connecting with Samsung the problem solved itself. It looks like almost all BMW's don't like iPhones because of many other issues with charging and using the loudspeaker system. Try using phone with android and if this fails, contact an authorized service center.
      11-14-2023, 03:58 PM   #3
Gamb1t
Gamb1t's Avatar
Mine came with an iphone caddy that connects to the car. IIRC it sat in the middle compartment. I promptly removed it as I have no use for it. It's left on a shelf in the garage.
      11-27-2023, 03:22 PM   #4
maxwmiller
Drives: 2013 X1 xDrive2.8i
If you are looking for a cheap and easy solution, a FM radio transmitter will create a bluetooth connection to your device, then project radio waves that you can listen to. They're usually $20 or less.
Otherwise, these infotainment systems are just starting to get obsolete, and there's not a lot that can be done without a complete replacement. Keep in mind that the technology in the factory system came out at the same time as the iPhone 5.
      12-06-2023, 03:15 AM   #5
forebittlancome
Drives: Maybach
car
Halfords offer a wide range of car stereo systems and Bluetooth car stereos.
geometry dash unblocked
