      06-29-2015, 11:29 PM   #1
jaeezzy
Enthusiast
jaeezzy's Avatar
28
Drives: BMW X1 sDrive18d M Sport
is it alright to install peel & stick sound insulation underneath front wheel wells?
Hi guys just wondering if I can install peel and stick foam sound insulation underneath front wheel wells to block out those holes and in a hope to cut out some engine and road nose The material is 5mm thick and advertised as damp proof. I heard that such materials could help in condensation causing rust to develop. I have installed it from inside in the engine compartment and wanna know if I can install it over the wheel wells' plastic covers and the metal part in our front wheels which I hope will help reduce a lot of tyre noise to penetrate through the wheel wells and through the firewall into the cabin? I see our X1 have quite a fair bit of work done at the rear wheels for noise but nothing at all at the front wheel areas.
Appreciate all your suggestions.. thanks
jaeezzy...
      06-30-2015, 07:02 AM   #2
elfhearse
CW5
elfhearse's Avatar
Drives: 14 x28iS/10 e91M/00 Z3MC
2014 BMW x28i  [0.00]
2010 328iT  [0.00]
I used aluminum tape (HVAC) to cover the openings in the metal portion of both front wheel wells to keep water/snow/road salt from entering the engine compartment. No problems if its installed over a clean surface IMO.
CURRENT:
10 328iT ZMP-6spd, 00 Z3 MCoupe, 76 2002 stg.2 5 speed
PAST: 96 318ti Cali, 03 325Ci, 00 Z3 M Roadster, 99 Z3 2.8 Coupe, 14 X128i M-Sport14 Z4 28i Sport 6-spd
      06-30-2015, 08:23 AM   #3
jaeezzy
Enthusiast
jaeezzy's Avatar
28
thanks
jaeezzy...
      06-30-2015, 08:55 AM   #4
Dmitry83
Russian Federation
54
Drives: F30 320i (328i ECU) M-Sport
This car improves best if insulate the roof- this brings the biggest difference.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler
F32 bottom V-bar
F80 bottom reinforcement plate
Koni Sport, M-Performance springs, M135i Anti-roll bars
      06-30-2015, 07:22 PM   #5
jaeezzy
Enthusiast
jaeezzy's Avatar
28
Thanks.. would you have any instructions on how to get to the roof? plus I have moon roof which I guess makes it even more prone to road noise?
jaeezzy...
