      06-06-2015, 07:48 AM   #1
cooombs
Drives: 2018 440i xDrive
Grinding/vibration from fan
A little annoyed to have to be posting this but it appears my 3 day old X1 is going to need its first trip back to the dealer. Has anyone had a grinding or vibrating sound come from the front passenger side when your slowing down or idling in traffic or a red light? It seems to be when the car is warmed up or the AC is on for a bit and it sounds like it's coming from a fan sort of behind the passenger side headlight. As soon as you start accelerating again it goes away and then comes back when slowing down and then at idle. I've found if I don't drive aggressively at all and don't turn the AC on I can drive for at least 10 minutes without it happening. Turning on the AC appears to make it do it within a few minutes.
      06-10-2015, 09:01 AM   #2
zero-2-sixty
Drives: X1 xDrive35i
never had an issue like this....it's new so take to your dealer and have them investigate. hopefully, they can reproduce the vibration and fix it. take your service advisor and technician for a drive and let them listen for the noise
      07-15-2015, 09:39 AM   #3
cooombs
I forgot to update this for anyone else that might come across this issue. Took it to the dealer and had them go for a ride to reproduce the sound. They ended up adjusting the "cooler line", not sure what that is but the sound is gone and has been for almost a month now.
