      02-04-2016, 12:01 PM   #1
Aerospike
Drives: 2013 F20 M135i
i35 in Manual Mode
Can someone tell me why the i35 will no shift down to first gear on its own when coming to a stop in manual mode? To clarify:
You're driving in, say, M6.
You're stopping, but you don't downshift yourself, you let the car do it.
The car keeps shifting down to the M2, but even if it comes to a complete stop it will not go down into M1 unless you push the shifter forward once.
Why??? Am I the only one who has this problem?
      02-04-2016, 12:10 PM   #2
PrematureApex
I mean, it's not a "problem" per say. It's intentional.
You have two options, move it into first yourself, or start from second.
I'm not sure why they programmed it that way though...
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      02-04-2016, 12:47 PM   #3
Aerospike
It's not a problem now that I know I'm not the only one whose transmission does this. It's now one of the little things BMW does that annoys me, like manually having to switch the GPS to night mode when the car has at least two different light sensors on it.
Thanks!
      02-04-2016, 01:09 PM   #4
PrematureApex
I mean, you are in manual mode afterall. So it annoys you that you actual have to...you know...manually shift it?
I guess that's the answer then...
It only downshifts through the other gears to prevent you from stalling (you should be downshifting it yourself, you're in manual mode). The car is perfectly capable of being slowed and fully stopping, as well as pulling away in second, so there's no reason to make the shift to first. The other downshifts are out of necessity.
      02-04-2016, 11:56 PM   #5
mwtrogus
Drives: 2014 X1 35i
I have the Alpina trans flash and i think it will go to 1st. I know it does in the sport setting for sure, I'll check the M mode tomorrow and report back. The flash is really worth looking into, the car is mellow and shifts early in regular drive mode and then is much more intuitive/aggressive in sport/manual mode. Adds gear indicator on dash as well. Look at other 335 forums for full details... and actually some guys report faster 1/4 mile times when launch car in 2nd vs 1st(wheel spin and the extra shift)
      02-05-2016, 08:42 AM   #6
Aerospike
Having to downshift doesn't annoy me. It's BMW logic that does. Either do the entire job of downshifting or don't do it at all. I'd rather have a no crap manual mode where the car doesn't downshift at all.
I've thought about the Aplina trans flash, but I'm still under warranty. Just another 25,000 miles to go.
      02-05-2016, 08:51 AM   #7
PrematureApex
It's your logic that's flawed. The only reason the car does any down shifting in manual mode is to prevent a stall, or being unable to pull away once you've stopped. It's bailing out your bad/lazy driving. You're in manual mode. That means up shifting and down shifting is your responsibility. Why would it do an extra down shift that it doesn't have to when you're in manual mode?
In manual mode, most people want the LEAST computer controlled shifting occurring as possible. In this instance, that's making up for your poor driving, while leaving the car running/operable...aka second gear.
It is a factory flash. No warranty concerns.
      02-05-2016, 09:08 AM   #8
black-box
Drives: 2013 X1 xD35 (1998 M3 RIP)
I wonder if it would drop into first if it sensed you were pulling something, heavily loaded, or driving through mud? If it's just the weight of the car to be pulled, the engine has plenty of torque.
      02-05-2016, 09:15 AM   #9
Aerospike
Wow, you have some very strong views about my driving. Believe me, I don't need bailing out. I've ridden my motorcycle in Rome, Paris, Madrid, London and Cairo. I'm very comfortable shifting for myself with my right hand or left foot.
Good to know about the Alpina flash.
      02-05-2016, 09:27 AM   #10
PrematureApex
I guess I'm just a bit confused.
Most people, presumably, would want as little automatic shifting as possible when in manual mode. That's what BMW gave you.
If you're in manual mode, why aren't you doing the downshifting? And why do you want more automatic intervention?
      02-05-2016, 09:35 AM   #11
Aerospike
I don't want automatic intervention, I wanted the six speed manual and a third pedal in the car. I'm just exploring what the transmission does. My GF's VW shifts all the way down to 1st in manual mode and she has the 2.5L turbo, which has OK power. This is my first auto car with fake manual mode and I was wondering why it did what it did (downshifting to M2, but not M1). I wonder if the eight speed in the i28 does the same thing.
      02-05-2016, 10:04 AM   #12
themishmosh
Drives: BMW X1 xDrive35i
The downshifting on our cars seems to be done too early. I will often try to downshift only to find the tranny shifted down just before I did--the result? I'm in the wrong gear. I think if you are not in any hurry, starting from a stop in M2 is smoother than M1 because the M1-to-M2 shift is not smooth at all (lurches forward in most cases). Maybe BMW is trying to avoid that.
      02-05-2016, 10:36 AM   #13
Aerospike
Too early? I have the opposite experience. It's always a gear too high around turns. Like PrematureApex said, the transmission just tries to keep the car from stalling. It doesn't really set you up with the right gear to enter a turn.
      02-05-2016, 10:45 AM   #14
vstolpner
Drives: 2019 F39 X2 m35i
The eight speed doesn't downshift to first in manual - haven't been in a car that does. I agree with PrematureApex - manual is manual and the car shouldn't interfere except when it will cause a problem (like stalling), it should let me do the thinking and let me control the situation.
That said I'm actually very happy with the way the weight speed performs, especially when pulling away and hearing it shift every 500rpm for what seems like an endless supply of gears... Lol
Edit: actually correction to my first statement - if I recall correctly, my '11 Impreza used to down shift to first gear but only after I came to a complete stop and even then it waited a second or two before doing it. Of course that was a 4-speed auto so the second gear didn't have as much pull as it does in our gearboxes.
      02-05-2016, 11:04 AM   #15
Aerospike
Now that I thought about it, my GF's VW has a DSG transmission so maybe that's part of the necessary programming.
      02-05-2016, 11:16 AM   #16
PrematureApex
It's always in a gear too high? Again, it is in manual mode. You are in a gear too high!
      02-05-2016, 11:19 AM   #17
Aerospike
It's always a gear too high when I experiment with how the transmission behaves. Happy?
      02-05-2016, 01:03 PM   #18
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
The eight speed does downshift to first in all modes including manual.
      02-05-2016, 01:15 PM   #19
WolfGTI
WolfGTI's Avatar
Drives: '17 F22,15 E84 M Sport,02 R53
2017 BMW M240i  [0.00]
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
Correct the 8spd will downshift to 1st IF the rpm range is safe to be in 1st gear.
      02-05-2016, 02:50 PM   #20
d1saster
Bulgaria
60
I meant when stopping it'll automatically downshift to first while the six gear auto transmission will shift to second at stop except in sport mode.
      02-06-2016, 03:14 PM   #21
mwtrogus
Drives: 2014 X1 35i
My 6 speed auto with Alpina flash does not go down to 1st on its own when in manual mode... it will go to 2nd when coming to a stop
