      12-15-2016, 01:33 PM   #1
jlombar5
jlombar5's Avatar
34
Drives: e90 bmw 335i
would these fit?
D-Force LTW5 18x9.0" ET41
would these wheels fit my 2013 x1?
335i 6spd jb4//KW clubs//FL5s//r888rs//5 inch IC//AR Dp//E85//spec stage3, lw fw//stage 2 pump//Sparco halos//straight piped// pfc-08s//CPE CP//braille//lsd// solid subframe bushings//m3 arms//rb inlets//e93 m3 f-swaybar//er dual oc//cae shifter//APR GTC250 wing//Mode carbon gt4 splitter
2013 BMW X1 dd
      12-15-2016, 05:30 PM   #2
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
They're going to be an inch closer to the suspension, so, maybe, but really not the optimal backspacing.
      12-15-2016, 06:12 PM   #3
Gamb1t
Gamb1t's Avatar
You can use www.willtheyfit.com or rimsntires.com to check fit.
Assuming you have the standard stock 17x7.5 with ET34. This will bring it 7mm closer to the suspension and more importantly the new wheel is wider than the stock by 1.5".
      12-15-2016, 07:40 PM   #4
Dalco450
Dalco450's Avatar
Drives: X1 M-Sport
Rear: no problem.
Front: will not fit, need spacers (I tried it last summer)
      12-16-2016, 09:41 AM   #5
jlombar5
jlombar5's Avatar
34
Originally Posted by Dalco450 View Post
Rear: no problem.
did they look ok with the spacers?
2013 BMW X1 dd
      12-16-2016, 01:54 PM   #6
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Can't you get those wheels with BS of about ET30? My stock wheels were 18s, with ET30 and width of 8"
