      04-28-2021, 12:36 PM   #1
bassrebel
The Lazy one...
Drives: 16 C300 4Matic
Coolant leak... where?
So after I finished all the trouble of diagnosing and fixing the engine stuttering I have now come to a new problem... coolant leak lol...
The coolant is dripping by the passenger side... I tried looking for the usual signs, bleeding screw, radiator cap... replaced both and it's still leaking... The car is not overheating, the fan is not always on, so I don't think it's the water pump... what can it be??
Any usual N55 leaks? Any help will be appreciated
Follow me on Instragram @bassrebel
2014 BMW x1 x3.5i 2016 Benz C300 4Matic
      04-28-2021, 12:41 PM   #2
bassrebel
The Lazy one...
Just to add... whenever I fill up the tank and run the bleeding procedure I don't see any leaks... however, once the car has come to temperature that's where I see the leak.
      04-28-2021, 12:54 PM   #3
bassrebel
The Lazy one...
Attached pictures of where I see the leak
      04-28-2021, 05:44 PM   #4
projectbarnie
Drives: 2014 x1 X35i
I had a leak at my expansion tank. Replaced that and the leak went away.
      04-29-2021, 07:23 PM   #5
bassrebel
The Lazy one...
Do you know the reservoir capacity???
      04-29-2021, 07:46 PM   #6
projectbarnie
Sorry no idea... shop did the fix for me.
      04-29-2021, 08:54 PM   #7
bassrebel
The Lazy one...
I went ahead and ordered one either way... if the leak is not persistent all the time then I can remove the possibility of a hose... if the leak starts once the car comes to temperature then there's a chance that the reservoir has a leak somewhere... crossing fingers!
      04-30-2021, 01:04 PM   #8
chance91
Drives: 2011 Bmw 335d
Hopefully it is the tank. Of note, if the cap releases pressure, it leaks out the bottom of the tank. If you look around the cap there is a hole that goes through the middle of the expansion tank to leak out. So maybe its a bad seal on the cap and leaking out bottom of expansion tank.
Very hard to say from photos, as a lot of coolant lines over there. as well as the waterpump.
=||=2011 BMW 335D MSport =||= - gone but not forgotten
2008 BMW 335i FBO
2015 BMW x1 35i DD, mhd stg1
2005 MX-5 LS swap
      05-01-2021, 06:13 AM   #9
bassrebel
The Lazy one...
Hm, I do know that the cap was all sorts of messed up... I'll try with the new cap first, if it works I'll return the tank then 😜
      05-01-2021, 03:25 PM   #10
bassrebel
The Lazy one...
New development!!!
https://drive.google.com/file/d/1xeF...w?usp=drivesdk
Here's a video I took of the leak... it looks like one of these two hose is the culprit!
Halp!
      05-03-2021, 11:30 AM   #11
chance91
New development!!!
Halp!
Still pretty hard to tell. I Think you may want to bring it in to a shop on a lift with the undertray off.
Hate to say, but that looks like the hose going to the Waterpump. Concerned the waterpump gasket may be cracked or gasket leaking = $$$
Hopefully you can just tighten the hose clamps?
https://www.realoem.com/bmw/enUS/par...-X1_35iX&mg=11
https://www.realoem.com/bmw/enUS/sho...diagId=11_4468
2008 BMW 335i FBO
2005 MX-5 LS swap
      05-03-2021, 11:39 AM   #12
bassrebel
The Lazy one...
Based on the angle it looks like the leak is towards the radiator... My shop will take a look at it later this week and replace what's needed.
      05-18-2021, 05:39 PM   #13
bassrebel
The Lazy one...
I finally had some time to check this out and it turned out to be the water pump that was leaking... I went ahead and replaced the thermostat as well
