      05-26-2014, 02:55 PM   #1
hessan
Drives: 2003 z4 2.5
upgrading standard speakers
hi there,
I plan on to upgrade my mid ranges to hifi and add tweeters. whats makes me confused is that there seems to be 2 hifi models that fit . (not top hifi)
one has a large magnet the other has a very small one.
any thoughts?
vs
      05-26-2014, 04:46 PM   #2
Dmitry83
Russian Federation
54
Drives: F30 320i (328i ECU) M-Sport
Hi,
As far as I remember from my E81- I've bought the big ones and it turned out it was either developed to work with Logic 7, cut off at the low frequencies like 100Hz and below, or with the powerful amplifier- the sound was overloaded.
So I've put back my small magnet ones, and just added the tweeters.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler
F32 bottom V-bar
F80 bottom reinforcement plate
Koni Sport, M-Performance springs, M135i Anti-roll bars
      06-02-2014, 02:32 PM   #3
x1x28i
Drives: 2014 X1 xDrive 28i
The small magnet version is probably a neodymium magnet, which may be equivalent to the larger ferrite magnet. I would not doubt the product of magnetic field and winding length (which gives the force per unit current) is the same. I don't know if the drivers are actually different, though. Why not get a better set of speakers, like the Morel Hybrid Ovation II, or the Focal IFBMW or 100KRS? There is also a new option from Rockford Fosgate for BMW (Don't' know if they're any good). Cost might be a factor, I suppose…
      06-02-2014, 06:17 PM   #4
Dmitry83
Russian Federation
54
You are right- the one I had is a neodymium magnet one, so seems it is just having a lower Fs, so better handling a full low range or something- don't remember exactly how Qts, Vas and Fs work together (though, we do not even have those measured).
Interesting idea on Morel, as they usually have very high sensitivity and can be easily amplified with the stock amp- have to check if their Qts is close to 0,7 as before they made a lower Qts midranges- for small volumes only or for the low range cut off.
Rockford is traditionally rough sounding, immortable at overloading, but they are also able of developing speakers with amazing sound quality.
Focal should be nice, but little bright.
Eton is the one I would put an eye on.
