      08-06-2011, 11:57 AM   #1
pcollinge123
Drives: X1 2.0d also 1 Series 2013
Exclamation wind noise over70mph, possible windscreen
Anyone had trouble with wind noise over 70mph ? Ours just gone back to the dealers who will hopefully cure !
      08-06-2011, 12:10 PM   #2
xspencex
Drives: BMW X1 18d
Yes, I have the same issue but I haven't had it fixed yet. I did notice that the rubber trim around the windscrean was loose (at the top corners), and I suspect flapping at speed.
Mine is especially prominent when there are cross winds. This post just remined me I really must get that sorted.
      08-06-2011, 03:50 PM   #3
mario486
Mario
mario486's Avatar
Scotland
26
Drives: X1 XDrive 2.0d, Mini Cooper
Its a well known problem with some X1's. There is quite a long thread on here somewhere about it. There is a fix and your BMW dealer should be aware about it.
"Do or do not, there is no try!" - Master Yoda
"Always in motion is the future" - Master Yoda
"Truly wonderful, the mind of a child is" - Master Yoda
"There is no passion to be found playing small - in settling for a life that is less than the one you are capable of living" - Nelson Mandela
      08-06-2011, 06:43 PM   #4
tompak23d
tompak23d's Avatar
Drives: iX M60
Hmm, funny. My noise comes around 160 kph...
      08-07-2011, 12:13 PM   #5
pcollinge123
Will post when i get the car back on Tuesday, will be interesting to see if they sort it !
      08-08-2011, 04:49 AM   #6
Exotic Hadron
X Eins in der Luft
12
Drives: X1
Are you gentlemen talking about that problem with that lousy rubber window bent that BMW Service used to address by patching it? I mean this post in that thread.
      08-11-2011, 02:42 PM   #7
pcollinge123
X1 been back to the dealer and it had a poor seal round the windscreen !
This seems to be a widespread issue ,if you have a problem with noise take it in .
Hope this helps
      08-17-2011, 10:48 AM   #8
DWB1873
Drives: X1 20d xDrive Auto
Hope this helps
Well, my February 2011 X1 seems to be fine on this front. Was in the UK at the weekend and had no wind problems (parp) up to an alleged 100mph (clearly over-reading, officer). Also didn't notice much noise from the mirrors, something else others have commented on.
I do, however, have that other favourite, the driver's side door rattle.
Tags
possible windscreen, wind noise over70mph
