04-06-2023, 06:52 PM | #1 |
Rep 30
bad smell from vents X1 2014
Hi, I am bit confused on the location of filters( i watched several youtube videos) and followed 1 to replace cabin air filter which is located outside under the hood. It's a long filter.
But since the smell is still bad, i saw a video where a mechanic replaced 2 cabin air filters which are located inside under the glovebox on passenger side. Does X1 28i 2014 have these inside-cabin-filters and do i need to replace them to get rid of smell? I took the car to dealership and they did Frigi-Fresh thing but no difference in smell. Pls help |
04-27-2023, 08:59 AM | #4 |
Rep 6
Apparently some have had success with spraying Lysol on the evaporator. If you remove the cabin filter that is located under the hood at the base of the windscreen, you can see the blower motor. I believe the evaporator is located under the blower motor. I have not tried this btw.
04-27-2023, 09:02 AM | #5 | |
Rep 30
With A/C ON, it doesn't smell. Thanks i will try lysol |
05-02-2023, 12:28 AM | #8 |
Rep 30
05-02-2023, 02:29 PM | #9 |
Rep 434
