      07-02-2013, 09:26 AM   #1
odieman23
Drives: BMW X1 xDrive28i M-Pkg & HK
Glovebox USB, X1 with Navigation
Has anyone used the USB inside the "glovebox compartment"?....apparently in theory...is used to: UPLOAD and DOWNLOAD music into your 12GB space you have to add media in your hardrive....
I'm waiting on mine...I should have my X1 by the beggining of august.....
I just wonder if you can use it for those things or multiple things....like "leaving a flashdrive connected with 32gb of memory with alot of music...
      07-02-2013, 11:08 AM   #2
Grovsnus
Flight Lieutenant ≛
Drives: Le Mans blue X1 35i
No, but you can use the front USB port for that. You can get some pretty tiny USB sticks these days - I have a 30 GB one there for exactly that purpose.
      07-02-2013, 12:41 PM   #3
eric9610
Drives: 2020 Telsa Model YLR
I have used it and it works well. The glove box usb port is also where you update the idrive system from.
2021 MYLR (c), 2016 MB E350 (c),2018 MB E300 (r), 2019 AMG GT63s 4D (r),2018 MB E63S (r), 2018 911T (r), 2014 X5M (r), 2013 X1 35i (r),2011 M3 (r), 2010 328i (r), 2008 M3 (r),2005 330ci (r), 2004 Lotus Elise (r), 2004 X3 (r),2002 330ci (r), 2002 Hummer (r), 2002 MB G500(r), 2000 Z8 (r), 2000 323cic (r)
      07-02-2013, 01:45 PM   #4
odieman23
I also read that if you insert a CD and save it into your hard drive ....you can export it through there with a stick...
Also "Grovsnus"...have you tried a portable hard drive or a higher stick....like a 64gb??
      07-02-2013, 03:28 PM   #5
sfillion
Drives: 2012 X1 xDrive28i & 128i M
I use a 64gb in my X1 (instead of the internal hard drive) and my 128i without any problem..... works great.
      07-02-2013, 05:27 PM   #6
Grovsnus
Flight Lieutenant ≛
How do you format it? Normally, Windows will only allow FAT32 up to 32 GB, and I don't think the iDrive can read an NTFS or ExFAT drive. FAT32 with bigger sector size using a 3rd party program?
      07-02-2013, 05:35 PM   #7
Grovsnus
Flight Lieutenant ≛
I don't think the port can deliver enough juice to run a portable hard drive. It might depend on the drive, but it doesn't have enough juice to more than trickle-charge my phone, so I haven't tried a HD.
I have used a 64 GB stick with two partitions on it - it saw the first partition just fine.
But you can fit a decent amount of 320 kbps MP3s on a 32 GB thumbdrive. It's enough to go on a week's vacation and never play the same song twice.
If it could do FLAC, yeah, I'd want to use a much bigger drive. Perhaps the next upgrade to iDrive will have a FLAC codec?
      07-08-2013, 07:46 AM   #8
sfillion
Fat 32... I didn't used any 3rd party program.
      07-08-2013, 10:48 AM   #9
odieman23
Thanks all for those post..keep posting...also if any of you manage to use an external drive..let me know
