06-25-2019, 07:50 AM | #1 |
Rep 18
Steering Wheel compatibility question
Hi,
I want to retrofit multifunction control and also to replace the steering wheel with this one https://www.ebay.it/itm/293120845256 which should be compatible with my E84, I asket the seller and he told me that is not compatible with my car even though this steering wheel which look the same is compatible https://www.ebay.it/itm/331696848808 Can you help me with this? PS: Do you know what else I need to retrofit multifunction control? |
06-25-2019, 03:09 PM | #2 |
Specialist
1310
Rep 2,708
The actual steering wheel will work. If you don't have a similar airbag you need to get one. You can use 3er, 1er, X1 or Z4 steering wheels. However I believe the multifunction control is trickier and requires a few more things. In the US all cars come standard with multifunction so I'm sorry but I couldn't help you with that part of the retrofit.
06-26-2019, 05:26 AM | #3 | |
Rep 18
The steering wheel in the first link comes with the airbag. Will go to the dealer to check what's needed to retrofit mfc. |
