      02-06-2023, 09:54 AM   #1
Lknight
Drives: bmw x1
X1 LED upgrade fault flickers
Hi everyone,
I recently changed the low beams and high beams on my x1 2013 to LED plug and play lights. They work fine and i have managed to remove all fault codes through bimmercode by switching the hot and cold monitoring to not active.
Though despite doing all this everytime i start the engine the lights momentarily flicker and then after this they are fine. I have heard to switch off all hot/cold monitoring which i think i have done on expert mode bimmercode but i am still getting this issue when starting the engine?
Any advice at all would be appreciated?
Thank you
      02-06-2023, 03:15 PM   #2
cwickberg
Drives: X1 35i MSport Ultimate,
You can get anti Flickr devices or resistors... this helps with the flickering. Coding only takes care off the monitoring of the current draw.
Lots available on Amazon
