      03-05-2018, 07:29 PM   #1
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Wheel Fit
I've been using an offset calculator and think I'll be OK, but does anyone know if a 17x9 ET30 wheel with 255/40 17 tires fit on an E84?
      03-06-2018, 08:02 AM   #2
hooligan_G01
Space Shuttle Door Gunner
hooligan_G01's Avatar
6430
Drives: 2022 X3 M40i BG/Taco Red
I'm not running that size, but they should fit. Others here are running similar widths/offsets with no reported issues.
      03-06-2018, 02:14 PM   #3
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
PrematureApex would be a good person to ask. I know the wheel and tire will fit but I'm not sure which offsets you would need to run.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      09-05-2018, 08:53 AM   #4
RXeckless
Drives: 2014 X1 Xline
New here, same kind of question.
I'm looking at a winter package from a 328i Xdrive
but does anyone know if a 17x7.5 ET37 wheel with 225/50 17 tires fit on an E84?
Stock is 17x7.5 ET34 wheel with 225/50 17 tires will the 3 mm different effect the struts on the front?
https://www.bmw.ca/en/topics/offers-...style-394.html
      09-05-2018, 11:38 AM   #5
bucketfoot
bucketfoot's Avatar
They should fit with no issues. You are looking at being 0.12" closer on the inside.
With my track tires I'm at almost 0.2" with no problems.
This post sent using 100% recycled electrons.
      09-05-2018, 11:41 AM   #6
bucketfoot
bucketfoot's Avatar
The main drawback is really appearance. The X1 benefits visually from moving the tires out some, where you will be moving them inward.
But then I'll take the added safety and performance of winter tires over appearance any day!
      09-05-2018, 12:23 PM   #7
RXeckless
Thanks, I'm getting a great deal and only used one winter! And local to boot.
      09-05-2018, 12:40 PM   #8
RXeckless
Your tracking an X1? I used my Mazda RX-7 FD and RX-8 R3 for time attacks.
      09-05-2018, 12:59 PM   #9
bucketfoot
bucketfoot's Avatar
Yep, I get a lot of great reactions
https://www.youtube.com/watch?v=kXRWn5bJ7c8
      09-17-2018, 12:01 AM   #10
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
Nice video! How do the brakes hold up?
      09-17-2018, 09:40 AM   #11
0w40X1
Drives: 2014 BMW X1 s28i M Sport
I have a X1 s28i, and RX8 of which I tracked both.
I leave traction control on.
The rear brakes work more than the fronts on the X1, since they are used as a differential power shifter.
I tracked RX8 approx 15 times and X1 approx 5 times.
I NEVER tracked the RX8 after I got the X1 becuase the X1 felt like more power, and more fun.
RX8 can maybe hold more speed in a corner, but the pull out torque of X1 over shadows that.
I wouldn't consider even messing with suspension or alignment on X1 car feels so good.
I had to buy BHR fuel pump and ign, Bilstein B12 suspension kit, and 2 alignments to get RX8 to work on track.
X1 s28i only needed 12mm front spacers, and still worked pretty good on Pirelli P7's run Flat summers.
      09-17-2018, 10:22 AM   #12
bucketfoot
bucketfoot's Avatar
I've done a minor upgrade to StopTech slotted rotors, Hawk brake pads and Motul brake fluid and these perform great.
The first couple of times I went out were on the stock rotors/pads. They were pretty good, although I did notice some fading. Although it's equally as likely that the stock fluid was the culprit.
      09-17-2018, 03:59 PM   #13
bucketfoot
bucketfoot's Avatar
Same here, I bought the X1 over a 3-series because of things like the added ground clearance. So why would I want to lower it.
I can understand other people doing so, but it defeats the purpose of the car for me.
      09-18-2018, 03:15 PM   #14
lmbxcfls
Drives: 2015 X1 35i white Motorsport
As to the original inquiry: I'm running 18x9 ET30's (ARC-8's) with 255/40's (Pilot Super Sports) all around on my E84 X1 with stock M Sport suspension. No fitment issues whatsoever. Replaced the factory staggered 19's -- ride, handling, turn-in all noticeably improved.
