      06-21-2023, 09:32 PM   #1
gJesus_1911
gJesus_1911's Avatar
Drives: BMW X1 E84 N55
E84 N55 Transmission Temperature
Hello All,
Does anyone know at what temperature does the transmission starts to cool down? Or what temp does the valve open to start cooling mine has reached up to 218F is that normal for the transmission ? I will attach a screen shot of the temp. Any help will help I wanna know if there’s an issue with the valve or radiator drain plug.
      06-22-2023, 07:10 PM   #2
cwickberg
Drives: X1 35i MSport Ultimate,
What model? What engine? Do you have oil / transmission cooler?
      06-22-2023, 07:21 PM   #3
gJesus_1911
I have a 2013 BMW X1 X35iXDrive the E84 N55
It does have an oil cooler however the transmission has a bypass I believe that is connected to the coolant system.
      06-27-2023, 03:46 PM   #4
Gamb1t
Gamb1t's Avatar
Is 232F a normal engine temp for an n55? Seems on the high side.
      06-28-2023, 07:12 PM   #5
wheela
wheela's Avatar
Drives: 2015 BMW X1 35i M-sport
I think 232F is pretty normal for coolant temp. Putting around I think they run 230's, and getting on the gas the setpoint drops down to 215 - 220 ish.
      06-28-2023, 09:05 PM   #6
wheela
wheela's Avatar
I've read n55's normally run hot by design for efficiency, then at WOT, the setpoint reduces for performance. I believe they target even higher temps in eco pro mode.
      07-01-2023, 02:04 AM   #7
gJesus_1911
Hello all thanks for the replies however I was inquiring in regards to the transmission temperature I believe it is reaching some dangerous temps. I went ahead and purchased the burger Motorsport trans cooler kit for the 335i and 135i which I’ll be installing this weekend hopefully it fits.
      07-01-2023, 10:24 AM   #8
cwickberg
Just checked my X1 35i. Coolant was about 230, Oil about 245. Did not check trans temp but usually should be well under 200
      07-12-2023, 12:32 PM   #9
wheela
wheela's Avatar
For what it's worth, here's another transmission temp data point. I wasn't up to engine oil temp for very long, so I don't know if it would have risen much more. This was just after an evening commute, so not spirited driving or anything. Running Xhp stage 2 transmission flash driving in sport mode.
      07-13-2023, 11:04 PM   #10
gJesus_1911
Thank you so much for the logs let me know if it reaches higher mine went super high I would say I have now bypassed the trans heat exchanger with a BMS trans air cooler I haven’t driven it far enough to see the high temp but planning this weekend.
