03-05-2017, 01:14 AM | #1 |
Rep 128
Repairing run-flats
I discovered something this weekend -- some tire shops won't repair run-flats! I picked up a nail, which is not all that unusual. Fortunately, like most of the times I've picked up a nail, I was able to fill with air (I keep an air pump in the car) and keep driving for a while, not relying on the run-flat feature. Given that, I had it patched. The tire shop checks to ensure the integrity of the tire from the inside, but it's up to you to not run the tire on low pressure in a run-flat situation - in that case, the tire is ruined, and you must replace it.
Had it needed replacing (for being run while under low pressure, or due to damage to the sidewall), the tires would have been mis-matched, if adding just one tire. So, I was looking at replacing 2 tires, or probably all 4. This doesn't seem to be a great advantage of run-flats, especially if they're more expensive! I suppose even if you have conventional tires, you can face the same dilemma, but at least replacing all 4 tires would be cheaper in that case. I read some earlier threads on tires, and it seems like a lot of you just go with conventional and deal with the lack of a spare. It's rare that I use a spare, but sometimes it is handy; I suppose if necessary, you can resort to a tow, but that's annoying. I read some other threads, and I guess I have a few months to decide what to do. I found an article which said that BMW doesn't recommend replacing run-flats with non-run-flats, saying that it tunes the suspension for the stiff tires. Do you suppose they're saying that to CYA? Or might softer tires cause other problems? I wouldn't mind some cheaper, less harsh tires as replacements. I figure I have several months left on these tires, but they already are a bit worn at 17k miles. The previous owner must have been a bit aggressive, or these P7s don't last as long as I'd normally expect an all-season to! My previous car had Bridgestone 970AS, and I was pretty happy with those, particularly in the wet. I'm not beyond getting summer tires, although I'm not sure if I'd get full advantage from them. |
03-05-2017, 08:55 AM | #2 |
Rep 673
If you ever have to do an emergency brake and so within inches of the car in front of you then the summer tires have already paid for themselves. All seasons aren't the best at any season so a single emergency situation and you get the full advantage.
As far as non run flats go - that's the only thing I'll buy these days as I'm sure you've seen in other threads. Technically speaking BMW probably does tune the suspension for run flats, but at the same time the ride is much improved with non run flats. I wouldn't worry about the suspension tuning a just focus on what you prefer in the ride. Just keep in mind it's going to be a touch softer |
03-05-2017, 09:50 AM | #4 |
Rep 283
I'm sure you can repair a run-flat. Would the tire manufacturer guarantee that a run flat would hold air after it's been repaired and gets another puncture? Probably not, but I'm sure it's from a legal standpoint.
It's still just rubber, a standard plug kit will repair a run flat tire without issue. (As long as it's not a sidewall puncture or the tire isn't shredded) |
03-05-2017, 10:21 AM | #5 |
Rep 569
My question to the OP is how do you know that though you picked up a nail that you were not relying on the run-flat feature? Did the TPMS kick in?? Even if it did what did the inside of the tire look like? Was there any signs of run flat usage such as marbling?
When we took off our run flats the shop guy asked me about one tire as it was marbled on the inside side wall which is a sign that the tire had been run flat. I said as far as I knew it had never been flat as the TPMS had never signaled anything except when it got to be well below 10F. We looked at the other tires and noticed some very slight marbling as well. As for for shops not fixing a run flat. The problem is liability. The tire mfg typically defer the car mfg. Also if one has run on a run flat then the clock is ticking. Most are good for 100 miles. |
03-05-2017, 12:04 PM | #6 |
Rep 1,343
IIRC the shops will not perform repairs if the puncture is within a certain distance from an existing the patch or if it is close to the sidewall. Also no repair can be done if the damage is on the sidewall.
I carry a patch kit and compressor in the trunk of my cars. In terms of rft, I find my X1's 18" Continental SSRs to be quite compliant. YMMV. Last edited by Gamb1t; 03-05-2017 at 05:35 PM.. |
03-05-2017, 04:51 PM | #7 |
Rep 148
I plugged one of my run flats myself with no issue, probably 10k miles ago. I am still trying to decide if I want to go with run flats or non for my next set, but I am leaning towards non for the cost savings and ride quality.
03-05-2017, 07:09 PM | #8 |
Rep 435
One of our major shops outright refuses to repair tires.
This was explained to me in private that for every repair they turn away they usually get someone to buy new. It's a win win for them, less time and more money. On the other hand the shop up the road from me will plug and patch anything, even if the tire is 10 years old. No questions asked. All depends on where you go and who you talk to. |
03-05-2017, 07:16 PM | #9 | |||
Rep 128
Well, I look forward to buying a new set in a few months, so I'll have to obsess about what to get until then. ;-) |
03-06-2017, 12:14 AM | #11 |
Rep 35
Guys, I totally get non rft tires are superior. If my e84 had the ability to carry a spare without sacrificing trunk space like the f48, I'd say it's a no brainer. However, if you're like me and don't want to sacrifice trunk space for a spare, just realize that plugging a tire on the side of the road, in the middle of the night, in bad weather, might be a challenge. While chances are any flat incurred will be a slow leak, temporarily fixable with a can of slime and/or a small compressor, there's a chance you'll get a larger puncture and be out of range of roadside assistance (I'm a firm AAA believer.) I've had trouble plugging tires in the comfort of my own garage with good lighting. I'm sticking with run-flats in case of worst case scenario. I may be in the minority here
03-06-2017, 08:56 AM | #12 |
Rep 128
There is a convenience factor. I'm trying to get clear in my mind if it is better or worse, overall. It saves you from having to deal with jacking up the car and dealing with the spare. If you had to use the spare to replace a conventional tire, it was probably because something catastrophic happened to the tire, so either way, you're replacing that tire, and probably more than one to keep things even. The worst problem is that any replacements will be more expensive with run-flats.
Sooo... are there run-flats that are better than these stock ones? |
03-06-2017, 09:06 AM | #13 | |
Rep 819
03-06-2017, 09:13 AM | #14 | |
Rep 819
Most of the non-RFT tires I've looked at are in the $140-170 range, while the RFTs are basically in the upper end of that same range. There might be a couple that are $10-20 more per tire, but that's not enough for me to consider the expense as a factor in the slightest. |
03-06-2017, 11:08 AM | #15 |
Rep 1,343
A can of fix-a-flat, patch kit and compressor were standard on light-weight performance oriented sports cars prior to RFTs. Oh... and Roadside Assist.
3rd and 4th gen RFTs are pretty good now. They have come along ways. While I have not had the pleasure on the early RFTs, I don't seem to find much difference on modern RFTs vs non in terms of comfort. Maybe I have numb bums. |
03-06-2017, 12:20 PM | #16 | |
Rep 128
Meanwhile, the tires I had on my previous car, the Bridgestone 970AS, are listed on TR for $151. Hard to tell exactly, but RFTs seem more expensive so far as I can tell? |
03-06-2017, 02:17 PM | #17 |
Rep 673
Run flats are also heavier and hence will burn more fuel. Over the life of a set of tires that can be quite a large difference. They're also more ridgid and likely have lower rolling resistance, but I imagine the weight offsets that.
03-06-2017, 03:07 PM | #18 |
Rep 128
But weight is saved by not having a spare and jack. According the BMW statement I found, that's their motivation? I suspect it also has to do with not wanting to compromise on the already-small trunk space.
03-06-2017, 03:41 PM | #19 |
Rep 673
True, I'm referring to a can of slime and a compressor in the trunk instead of a spare
03-06-2017, 06:52 PM | #20 |
Rep 10,509
if it's in the tread and you haven't driven it without air, you can repair it.
I have repaired one in my driveway (with one of those kits from Amazon) after seeing a BMW tech (friend of a friend) do the same thing on another one of my RFT (unofficially, since the dealer policy was not to repair RFT) EDIT: I would suggest keeping one of those repair kits, pliers, and 12V air compressor and using those tools first (have personally had many thousands of miles of use on the repaired tires), before the slime in a can (which, from past experience, don't work.. barely made it 12 mile to a shop) |
03-06-2017, 06:56 PM | #21 |
Enthusiast
28
Rep 305
IIRC, I think I was told that P7 cinturato run-flat that happened to come with X1 was not repairable for punctures. I think I was told that some run-flats are repairable but not this one So, I had a nail stuck when I had just done around 6000 km and had to get a whole new tire for AUD $380. Now I'm running non-rft for almost a year - ContiSC3 in the front and Michelin SS in the rear (as my SC3 in the rear wore out like it didn't care). Lo and behold, there it was again, shining near the edge of the tire like it belongs there, just after a week of putting new SS on However, I was able to ride with it still stuck in the tire as the air wasn't leaking and my heart was broken So, took it to the tire shop only after a week or so and man was I happy - I got it fixed for just AUD $35. Lady in the reception cracked a joke and asked for $85 and I was ready and happy to pay the amt coz I wasn't sure how much to expect for the repair and it was still way cheaper than replacing the whole tire
Also, I don't have spare but just the repair kit from BMW in the trunk.
jaeezzy... |
03-06-2017, 07:28 PM | #22 |
Rep 330
Had slow leak in one of my RFT's and BMW Service repaired it. Might have even got a Tire shop to come in and do it.
I have a Non RF Staggered Set Up now and recently replaced my down to the tread line Original RFT's with 4x Non RF's onto the RF Rims. One lost air and luckily the tire monitor picked it up when i was in town, down from 40 psi to 17 psi but i drove a bit to find a park spot. I just got my Digital Pump out re inflated and drove to my tire shop, they repaired, taking a screw out. |
